Rifle case ......
See more from rd_ab_penman
rd_ab_penman
Red Deer, Alberta, Canada.
With Chrome Bolt Action Pen & Pencil set c/w Polymer Braid barrels.
Les
Then riddle me this batman, why does one have the lever all the way down and the nib is out and the other the lever is in the up position and it looks like the nib is also out. They do look like identical except for that lever thingy. :smile:
Then riddle me this batman, why does one have the lever all the way down and the nib is out and the other the lever is in the up position and it looks like the nib is also out. They do look like identical except for that lever thingy. :smile:[/QUOTE
To solve the riddle you need to put your glasses on and have a closer look.
Les
Well I like to thank you for the answer but I put another pair of glasses on and the same things keeps appearing. Not that it means anything to me. But the question is is it two pens or a pencil and a pen as you posted in the title. Others are asking.
Les
I hate to tell you this Les, but I see the same thing in the bottom pic.
Top pen, lever (slide?) is down, pen tip is out.
Bottom pen, lever (slide?) is up, pen tip is out.
When the Pencil Mechanism Tip is threaded into the Pencil Tip it is designed to protrude through the Pencil Tip.
When you close the bolt it advances the .07mm lead.
Les
