Embellished Bowl
See more from Cwalker935
Cwalker935
Richmond, Va
Still trying for the cloud effect, not quite there yet but I am pretty happy with this Bowl. 11" Cherry.
Great looking bowl Cody, but more importantly, PLEASE explain how the heck you manage to get so many projects completed !!!!! It seems every day you have another terrific piece of art on here. The only way I could do that would be to sit in my shop 24/7. Just tell us there are actually 4 of you posing as one person, we'll all feel better.
I also did 8 pens yesterday, 5 pens today, screwed up 2 travel mugs, got up leaves and watched football. First attempts at travel mugs tried to get by with blanks that were too small. Mug was looking pretty good, does it really need a bottom?
Now THOSE I can relate to, especially the screw up but I've only heard about them thru the grapevine or seen pictures like yours.
In answer to your question about it needing a bottom....nope. Just glue a block to it and call it a pencil cup. HINT: Outside of mug +/- 7.5", stainless liner +/- 5.5", hole in wood no more than 6.5" :biggrin:, taper inside hole like the liner or you end up with another pencil cup. I have lots of pencil cups (that were given to me by others trying to make mugs).
I've seen some of the smart guys turn old liners into make-shift measuring sticks like this one that tells you when to stop before you have another pencil cup. When you've screwed up as many as "those guys" , you develop some tricks. I'm sure "they" would gladly share, we have enough pencil cups.
Did ya watch the Cowboys win?
Sounds like "Those guys" are a fun bunch. :biggrin: Maybe I should get them together with "My sources".:eek:
Yep, more action in last 2 minutes than rest of the game. Also watched the Redskins hang on for a win.
SUPERMAN!!!! (I also was wondering how many hours in a day you have!)
If you need an extra bottom... I'm trying to get rid of one :eek:
Here is a pic of a cloud rim bowl done be a couple of our club members a couple of months ago.
I have watched the two videos (from Yoder and the original turner) 6 or 8 times each. I think the key is to thin the paint, and use little of it. layer over layer if you need to, but I think thin is the key. (that paint really jumps when it is thin!)
I can't wait to try one, once I dig a path to my lathe!... and learn to turn again... geesh!
Opinions are like... many things heh heh heh!
I love these things tho, some day ....
Great job Cody!
?....did you thin your paints before blowing?
Good to see you and your wifey at the symposium!
Good to see you guys as well.
Definitely thinned the paint, tried differing consistencies, Too thin paint- beads up, little thicker paint- does not spread smoothly. Tried different air pressures on air brush. I am thinking that my issue may be with background paint and preparation. I used a gloss enamel for the background.
Great job Cody!
In the pic I posted, they used interference acrylics...Golden is one brand.
They are sort of translucent and some are iridescent as well. I understand that some colors may appear different when applied that you think you will get....sort of a fun experiment! Of course what is under them can influence the final color too.
If you have an internal tenon on the bottom or a vacuum chuck, you could shave that off and have another go without turning another piece.
However, I think your bowl looks very cool the way it is!
Edit:
Perhaps you are on track with the surface causing issues. Maybe it was just too slick with the glossy paint. There should not have been any wax or anything involved. Even hand oils can cause issues.
You could try knocking the gloss back with some steel wool so the paints have a little more to grab onto. Did you use a clear coat between the black and the coloring?
What grit did you sand to before applying black paint?
I wonder if an itsy bitty touch of dish detergent or fabric softener in the paint would help it to flow better and not bead up as much?...sort of a flow aid as in automotive paints?
Great job Cody!
Edit:
Thanks. Sanded to 600 grit. I did not touch or treat the paint and applied the acrylics once it had cured. In the above video, he applied sanding sealer before applying the paints. Might try that next time. I am happy with the bowl the way it is and am looking forward to the next one.
Three conversations going on on this thread :biggrin:, one with the bowl, one determining if Cody is using a time machine to accomplish as much as he does, and the Travel Mug.
I found that a tumbler I made a few years ago consistently did not keep things hot or cold long enough; it had a single layer inside cup, and I could feel the temp on the outside as I griped the tumbler. Two years ago, I drilled two holes in the bottom and spray-foamed the inside inside. It has done much better since, in keeping hot things hot and cold drinks cold.
