Artisan iron designs
This is my shop, it is roughly 100' x 60'. Some of the tools I have are as follows. 9" SB lathe, 13" SB lathe, 50 kelo Kuhn power hammer, 80 lb drop forge, KF 27 Even-heat oven, wells index vertical mill, 2 coal forges, 5 gas forges from 3 - 12 burner, Ingersol rand rotary screw air compressor, 2 drill presses, badder III 2 x 72 grinder, 3 miller floor welders, 1 miller boom arm welder, 3 miller tig torches, 4 layout tables, DoAll band saws horizontal and a vertical, 55 ton geka iron worker, 125 ton hydrolic press, 2 ton bridge crane, Media blasting booth with fresh air breather, paint booth, and an eagle bender. sorry for the poor pic's but had to reduce them to fit the 3mb limit on forum. I use most of these to make my Damascus pens and the rest is for my estate gate and handrail work. I hope you like them. it only took 30+ yrs to accumulate all these toys.
