This question should be a first - wheelbarrows wheels
TonyL
Georgia
Hi Folks:
I bought a Costco wheelbarrow several year ago; still works great, but has an irreparable flat.
I learned that after buying a replacement from HD with a 5/8" or 3/4" bore/axel that mine has 1" axel hardware...so need a wheel with a 1"inch bore. All that I have found so far, claim to be universal, but not in same universe as the Costco one. I Googled and searched everywhere and using different search criteria, but no luck. Grainger, Hartfield, TractorSupply and all of the big box stores did have it. It doesn't have lugs. It's a 15.5/16 inch diameter tire that sits on a 9" rim and about 4 inches wide.
If you come across one or know where to find one, please let me know.
Thanks!
I had similar problems, with both my wheel barrow and my sack barrow. Assuming that your tyre is a pneumatic, instead of getting whole new wheels I bought inner tubes from my local car trailer shop. The last one I bought was a 10" x 4" for instance.
TonyW
TonyW
+1 for Tony's solution. I have an old craftsman mower that I bought new in 1973. The tires on it were tubeless and needless to say, will not hold air now. Over the past 2-3 years I have converted them all to inner tubes and now the problem is solved. BTW I only use it as a yard tractor these days pulling a tilt trailer behind it so that I don't have to use my vintage 1970s wheelbarrow that has a "flat" tire.:rolleyes:
Tony
Have you heard of slime. Green goop that goes into tubes to stop leaks. Very popular in Tucson with all the cactus thorns. One can buy bike tubes pre slimed.
Short of rips in the tire casing fixes leaks
Tony
Hardware store here has bushings that will fit over smaller shaft to match hole in mounting hardware. E.g. 5/8 inside and 1 inch outside. Some straight tube, and some flanged. Usually bronze but sometimes steel.
Washers as spacers as needed. Usually lasts 5-10 years
Tony
Ken, If I read the original post correctly, he has a 1" shaft and the new wheel is 5/8" or 3/4" so a bushing would not work in this case.
You might want to do what I did after replacing wheelbarrow tires several times. I bought wheels with solid rubber tires. I have 2 two-wheel wheelbarrows and both of them now have solid tires. One of them came as a two-wheeler, the other one I just replaced the short axle on the wheelbarrow with a long one and mounted two tires on the outside of the frame to make it into a two wheeler. At the time, I had horses....BIG horses...Belgian Heavy Draft, so I needed two wheelbarrows...one for stall cleaning, one for feed. I just don't have the upper body strength any more to keep a heavy one-wheel upright. It's a bummer to have to shovel all that "stuff" up twice after it gets away from me and tips over.
Thanks all.
Here is what I did before the post, I should have mentioned that the tube is beyond repair. I do have a slime-like product, but would wouldn't worked given the size of the tear.
I also hunted around for the hardware to replace metal straps used to use hold the 1" axel so that I can buy a new axel (with the use of reducer bushings) - "no dice" on that either.
I brought home the flat-free solid tire that HD and Lowes sells for obvious reasons and it accommodates 5/8 to 3/4" axel/bore. - so that went back.
While returning it, I had an inner tube in my hand, but wasn't sure that it was going to fit, so put down. (or "put it up" as I understand they say in GA :-) ).
Which brings me to you guys. Ah yeah, I spent 90 minutes searching the Internet too. I may give the tube a shot - or try harder to get the hardware to reduce the hardware to accommodate 5/8 (which looks like the standard) or 3/4".
Thanks again folks and enjoy the rest of Sunday evening!
Hi Folks:
Thanks!
I think I'd go for replacing the axle Tony
Tony
But if one was to junk the 1 inch shaft and acquire one that fits the tire, the bushings fit the holes in the frame where the old axle went.
Washers are shims to adapt widths
Not at all elegant, but a good farmstead fix
Some tire stores have the capability of filling the tire with foam. Makes it really heavy, but guaranteed never to go flat again.
FWIW
Bill
Thank you all!
Ben...you are never bugging me. I'm just busy with work during day. Looking forward to see you and the Mrs.
I put the metal lathe idea to rest for a while after talking to my family members three of whom are machinists.
My first choice is to find the hardware to reduce the axel...otherwise I will take a ride to TSC.
Thanks again folks. I always learn much more from you all them simply the answer to my question.
Going to go tonight and pick it up. The first pneumatic one lasted closed to 3 years. I hardly use a wheelbarrow. Funny, is that I check their site prior to writing this thread and again this morning and I still can't find the wheel. If it wasn't for Terredax, I would not have found it.
Have a great one folks!
I went to HF and they helped me. I replaced my tires on my hand truck (hard rubber) to air tires. They have over ten years and still going strong. If your tires are in good shape put tubes in as mentioned. They will work fine.
Preston
My cardio routine is walking up my driveway from the mailbox. It's a good 90 feet :-).
Visited two TSC, neither had it despite indicating in-stock on their website. Something will come-up; I am sure.
Preston
My hand truck came with pneumatic tires... I've had it nearly 40 years and still has original tires... it sits in my garage storage most of the time, only use it occasionally... one of the tires was almost flat when I needed it today. It needs a new axle since the one on it is bent and one wheel wobbles because of it.
I'd order it online if you can. Conversely, if you decide to go with a smaller axle wheel, I have some 5/8" steel rod stock here.
If you give me a length, I'll slice off a hunk & mail it to you.
I got some nice wheels/tires at HF for $10 each awhile back.
I never built the cart I was going to though.
