PC help again please!
Dalecamino
Local Chapter Leader
Indianapolis, In.
I'm using windows 7 ISP is U-verse Turbo speed with a D-link router. Since switching from IE to Firefox, most functions improved. But, when watching youtube vids or any other videos like, on other sites, the audio gets ahead of the video. I've been through all sorts of updates, and health checks, and come up with no apparent way to fix this issue. Also, I'm using MS Security Essentials.
Any suggestions?
You say you switched from IE to Firefox. I'm assuming video was working on IE before you made the switch.
Does IE still play right or is the problem there now as well?
Next time you get that choppy video, right click it, and click on "About HTML5"
It will tell you that youtube has automatically enrolled you in their beta testing and to opt out you click the link on the bottom to stop seeing HTML5 videos.
Yes, it was working with IE, but had other issues with IE. Also, there was a banner on Youtube that, said "Work better with Firefox" (something to that affect) Having had Firefox in Florida without issues, I made the switch. IE caused Yahoo mail to DRAG so bad here, is why I switched to Firefox. THAT part works. I've avoided switching back to IE so far, inhopes of finding the remedy. Although, that may be what I'll try. Thanks!
Thanks! I'll try that.
OK, I tried the HTML5 route. Sent a report on my issue. It seems to be working better on a short test run.
Thanks for the help!
Usual routine before troubleshooting deeper
Renew your IP address and reset your modem
reboot computer
uninstall and reinstall Firefox
restore your computer to the point before you installed Firefox the first time test with IE to confirm its working right then reinstall Firefox again and try it
reboot computer
OK, that will keep me busy for awhile :biggrin: Thanks Frank!
Chuck; You may want to try; Clear your cache files and cookies.
Clear Cache: Select "Tools", "Options", "Advanced", "Network" tab, click on "Clear Now". Check the "Limit Cache To" field and set it to no more than 100MB.
Clear cookies: Select "Tools", "Options", "Privacy", Click on "Show Cookies", type "youtube" and then click "Delete Selected" for all the cookies shown. Do the same thing for "google" cookies. You may have a corrupted cookie on your system.
Hope this helps...
Hope this helps...
Firefox has a different set up for clearing cache & cookies, but I got that much done. Tried going back to IE. It says it is already installed, but I don't see it in programs. and no icon on my desktop. I'm taking a break.
