monophoto
After we moved into our new home 13 years ago, I set up a small TV in my office. No splurge here - it was an old TV that had belonged to my wife's aunt. But when that TV eventually failed, I bought a replacement. OK - one of the modern flat screen units. Wow - I've moved into the 21st century (finally).
Yesterday, I started having a problem with an intermittent signal that I eventually tracked down to a defective HDMI connection - the connection at the cable box is OK, but the connection at the TV is loose. Several days ago, I inadvertently bumped the TV causing it to tip over, and I suspect that the stress of the fall put pressure on the point where the HDMI connector is soldered to the circuit board..
While it may be theoretically possible to repair, the practical solution is to replace the entire circuit board. And of course it would be less expensive to replace the TV.
When I bought the TV I didn't notice that:
1. The HDMI cable simply plugs into the side of the TV with no mechanical attachment between the cable and the TV case - so that any stress applied to the cable is transferred directly to the point where the connector attaches to the circuit board. That's a really lousy design!
2. This model has only one HDMI connector. Other models have more, some as many as four, so if one fails, there are spares to work with.
I'm an engineer, so I should have noticed the chintzy design and the lack of redundancy.
Kicking myself all the way to the store to buy a replacement - - -
