Clip material sourcing
InkyMike
Maple Valley, WA
Hello all
Long time reader, first time poster.
I'm working on a design for a kitless aluminum roller ball. I've read and searched through a lot of the forums here, but haven't found what I'm looking for yet.
I'm looking to custom make my clips - likely from 304 stainless. Each clip would be roughly .050" thick by .190" wide and 1 3/4" long.
I've found a place that has the material that thin (McMaster-Carr) but not nearly that narrow. I'm wondering if anyone out there has seen a source for very thin, very narrow stainless stock. I don't have a sheer at the moment, so making them from a larger sheet isn't an option - yet.
thanks!
~m
By chance do you have a router? In theory you may be able to shape it with a router if you make a template.
I know they have special router bits for non-ferous materials (brass, aluminum) not sure if they have them for SS. Just a thought since it is so thin, you might be able to sandwich it between thicker layers of wood or plastic.
Just a thought.
Hey Rob
Yeah, I have a couple routers - I hadn't thought about that, but it's definitely an option. My hope was to be able to find stock so I wouldn't have to waste a lot of material.
I suppose with the material so thin, I could also consider using a band saw or a chop saw, too. Long term a good sheer is likely the most ideal solution.
~m
Would a jewelers coping saw with a blade for stainless work?
That's an idea as well - I had considered a hand saw - I could work up a jig for it pretty easily
Rob - I'll give them a look
I've also sent an email to McMaster-Carr to see what they have to say
~m
Look for a sheet metal fabrication shop in your area. They may be able to shear the material for you. The cost should be minimal. Also look for a trade school or something similar. You may even be able to swap a pen you made for services .....
Just a thought.
Just curious RobS, have you ever worked with stainless steel? That stuff is really tough. I would not bring a router even close to it. It will wear a groove in a bit in an instant at that rpm and no coolant.
I like your idea of a stainless clip, and have a personal opinion to add. This idea would add to the amount of work involved, difficulty of fabrication and cost. Still want to continue reading? :eek:
My opinion, when looking at the available stainless clips, such as the cigar design, and some Lazerlines offerings is that a clip made from flat stock, although having a curved profile along the length, appears less refined than other typical clips. I am comparing to clips which have what would appear as a curved profile in a section view. This is accomplished in most cases by bending the edges over a bit. Now THAT would involve considerable cost/effort for the limited quantity production that I think you intend. My thought, instead, is to use thicker stock. (Ex: Lazerlinez uses stock about .04 inches thick. Perhaps stock about .06 inches thick might work.) With that extra thickness you could round over the edges of the clip with a little grinding, filing, sanding, and polishing. I have never done this, but believe that doing it, and doing it well, might enhance and refine the finished look of a pen sufficiently to make the effort worth while. Just one man's thoughts...:wink:
Just a thought.
Yes I have. I thought he said 0.020", I just reread it and he stated 0.050" which would be significantly more difficult. ~m at that thickness my idea would not work.
~M
Do you have a maker space near you. They tend to have a significant amount of equipment, that may solve your problem. Just a thought.
Mike,
OnlineMetals.com has stainless close to the thickness you want. Listed under 15-5 category. They would probably cut it to whatever size you want.
Rob
Another great idea - I think there are actually a couple not too far from me. I'll check it out (even if not for this, it's honestly a resource I haven't looked in to much)
Thanks all for the suggestions - looks like I have a handful of options
~m
Mike,
I'll have to give them another look - when I looked there initially, I didn't see it (or I did, and I didn't see the width I was looking for)
I've had a lot of good luck with them in the past
~m
I've used 0.030" brass and titanium for clips. The brass could be stiffer 0.40 would be better. Just right for grade 5 titanium. I used a metal bandsaw to cut to rough shape and a sander and file to final shape. Check ebay for sheet goods. Also knife maker supply companies carry similar thicknesses in many materials. Its used for pocket knife liners.
More4dan - any issues with cutting the titanium? I'd considered the knife makers as a lot of them make clips for their knives as well.
~m
~m
Gee, what makes you ask? Something designed for rockets, supersonic airplane skins, and other exotic high temperature applications should be a breeze to work!
Interesting idea. I have a pen I'm that has a stainless clip - and I measured the thickness, which is why I went after the thickness that I did. The edges aren't perfectly rounded, but they are round enough to not have an edge. Rounding them over would be cool...perhaps for phase II
~m
[/QUOTE]
Gee, what makes you ask? Something designed for rockets, supersonic airplane skins, and other exotic high temperature applications should be a breeze to work![/QUOTE]
Perhaps I can just toddle off to Boeing and they can knock a few out for me :)
~m
~m
I use titanium sheet for making pocket knives. It cuts easily with a metal band saw and I shape with a sander. I don't seen a big difference working it verses 316 SS. Drilling requires sharp bits for both and working through several diameters to the final size. To bend i heat with a torch first. Titanium can also be colored anodized with heat or electricity in colors from gold through blues purple reds or greens. Its high yield strength makes it a good springy material without having to work harden like brass or 300 series SS or heat treat.
