Would you buy good casting wood pieces...?
robutacion
Australia - SA Adelaide Hills
Hi Folks,
I have had this idea for a very long time because I produce a lot more of it than I ever will be able to use however, every suitable piece is trimmed to size and put aside so, nothing goes to waste.
In our days, casting wood blanks and other blanks has become a great experience for so many people, including a large number of IAP members that, took on the task with open arms, some are having better results than others many times due to lack of suitable woods/pieces for the task, which is most disappointing.
I have started casting long ago and since, I have helped many folks starting casting for themselves, I don't see it as working against me because it will compromise my sales of cast blanks, I don't really care about that, I prefer to stop casting when the interest is no longer there, on the other hand, there will always those that are just starting and that would never attempt to spend the money to invest on casting equipment and materials until they are satisfied that, they want to pursue pens and blanks making, for whatever the reasons.
With that said and as I mention previously, there are I believe a number of you that simply has no access of decent casting wood pieces and that is when I would come in, supplying those clean pieces.
I mean clean pieces because, freight/shipping is quite expensive and therefore I always aim to the best cost effective way to get things to you guys so, I would supply (unless otherwise requested) pieces of wood that have been trimmed to allow a general cast blank of 21 or 22mm square x 130mm long some of course, you can cast longer by adding multiple suitable pieces of the same wood.
These pieces are lightweight (most of them) so, I'm considering to put a few half a kilo to a 1kilo boxes together that can be filled with all of the same material or a mix.
Of some of the possibilities, 2 of which I have far too much of it are the beautiful Colonial Red gum burl pieces and the more recently acquired the Peppercorn tree burl, this is also a beautiful casting burl and is very light weight.
I have an issue with the Peppercorn burl I got, I don't have the space to put it all under cover and this burl has been considerably weathered from years in the weather. This is not all a negative as you may think, in fact, this burl is quite useless when green because it needs to dry to complete the nature cycle of natural decomposition which in this burl means, beautiful openings and lots of areas where the wood turn into a mass of spalted material.
Not all pieces require stabilizing but some of the most spalted, it would certainly improve its workability but having its harden before casting, as a matter of principle, I don't cast any wood without have it properly stabilized before end.
These boxes will be fairly inexpensive considering what you can do with them, there is no waste, every piece has been trimmed to general pen sizes.
I have plenty ready but not sorted or photographed, I started this thread after spending the last 2 afternoons processing one of the large pieces of the Peppercorn burl I brought home and to be fairly honest, the large percentage of these large pieces of old burl would be pretty much useless for anything else than small pieces like pen blanks, there is I believe about 10% of it that I can salvage as medium size bowl blanks, the biggest I processed to stabilized is about 1 cubic feet but most are smaller than that.
I will also turn a few items with this burl to show you how well it is suitable for many types of turning pieces .
I will leave you with some of the pics I already have of this burl, some raw, some stabilized, some soft and some hard some with no holes and some from the very outer part of the burl where all the natural holes are, after that, I will take some pics of the ready casting materials I have and post it here for you all to see and possibly make some orders.
Let me know if you are interested, I will provide prices very soon...!
Thank you,
Cheers
George
George, a mate gave a piece of Peppercorn Burl last year. I turned a bowl and I was turning more air then timber. Off the tool it was nice and easy, sanded easily and finished with oil, then spray poly.
Could take 4 pieces 1 1/4 to 1 1/2 square , 3-4 in long , with holes (the more the better) or spalt , soft is fine , for S&P shakers
Hi Wayne,
Sure mate but only 3 or 4" long? those would be some of the smaller S&P I've seen for some time...!
Would you like 2 pairs one with holes one spalted..?
If you can stabilize it yourself it would be a waste of money to pay that much more just in freight/shipping, this is fairly light weight stuff but after stabilized is a very different thing altogether, as you would expect, the spalted stuff is the one that loves Cactus Juice, drinks it like a Camel...!:eek::biggrin:
I will let you know when I got them cut...!
Cheers
George
G'day Pat,
Thank you so much for showing us your Peppercorn burl bowl, it looks great, interestingly, you don't see many pieces turned with it and I wonder why?
I would guess that some of your troubles with small pieces breaking apart was when it started to get thin, would be no surprise because it is quite fragile turned thin so, I'm considering preparing a few pieces for me to turn some from the burl's edges where the natural holes are but also some from the spalted "meat" of the burl and trunk wood, because that is the only part that spalts, on the pieces that I will turn, I will first rough turn and then dry (water) and stabilize then re-turn again to finish, that would save me lots of Juice and also will strengthen the half turned pieces.
Cheers
George
I'm always looking for casting pieces. I would be in for a lot of it.
I prefer the pieces from the outer bark side that look like a "martian landscape" or something similar with lots of "craters" and "mountains".
Looking at the pictures above, the peppercorn burl pieces that aren't from the outer edge would also be neat and something I've never done before with all the voids.
I'm in!
Lewis
Also, I really don't have a preference for wood types since I have no experience with Australian wood. I have purchased wood from you, but I haven't gotten a chance to turn it yet!
I think the Colonial red gum is beautiful and would be nice with several colors and the peppercorn burl would be nice with different colors.
Also, I stabilize, so I would not need them pre-stabilized.
Lewis
Hi Lewis,
One of the things you and most other people overseas will notice is that, I'm not into the Aussie commercial valued burls that you see everywhere from Australia, what I offer are the less known species that I collect from around here that the big timbers guys don't bother with, no great commercial value and quite frankly I like it that way otherwise, it wouldn't be anything left.
So, I see no difficulty in arranging an assortment of various types of casting wood, including the Peppercorn burl, Colonial Red gum, Olive root, Platypus Gum burl, Cork wood, Bottle Brush root, and many other I have been gathering over the years.
I will have some more pics of what I have ready and some box sizes and respective prices, you then can make your selection and I will put it all together for you, no problem.
I believe you are after pen blank pieces, isn't it?
I took a couple of quick pics this afternoon of some boxes I had on hand, I'm reaching for many other boxes full of stuff and re-arrange the mess slightly so, you will see more types of casting woods...!
PS: You better start getting the nerve to turn some of my blanks you purchased, they won't bite you...!:wink::biggrin:
Cheers
George
George,
I love the pieces in box #1! That's the type I like. I think they have more personality than the olive root pieces. I would be in for a pretty good amount of that.
I would be interested in maybe five pieces of the box #2 type just to play with.
And yes, I want pen blank sizes. I am anxious to turn your wood, but I make them mostly by order and I haven't had any takers for wood lately, except for the wood and resin.
I'm glad you decided to do this!
Lewis
George,
Lewis
Well, that good mate because, those are the ones I have the most from my recent findings.
I will show you all the types I can sell, I can take close up pics from each type to help you guys deciding but certainly, this Peppercorn burl as lost of potential...!
Be patient, you will have plenty to choose from...!:smile:
Cheers
George
Hi Wayne,
Cheers
George
3-4 inch is fine George , these are for S&P shakers , not grinders . The insert is less than 2 inches long . One set spalt and one not would be good . Don`t worry if both pieces in a pair aren`t the same length . I usually make one a bit shorter than the other .
I am totally familiar with the stabilization camel , and allow him to drink as I see fit .
Let me know shipping . May order more if not too bad .
Wayne
Prices, Prices?? Need wood, have wood BUT ALWAYS need more wood
Hi mate,
Prices are coming soon, don't worry.
At the moment, I have the oven full of cut Peppercorn burl to dry all the water out, since I processed the bigger chunks from the piece I brought home, they were very wet from the rain and these last few days the weather has been pretty nasty to dry anything, in fact it rained almost all day today, light constant rain.
The pieces I had already cut and shown in my last pics, still need drying and today, I processed a few more of the chunks I had cut so, I put them all in the oven and should be ok tomorrow night.
If we were in Summer here, the water in the burl would dry quick but we are in Winter mode so, everything takes much longer to air dry.
I already had some pieces dry from last week but they are a lot bigger pieces and I want to make sure, you guys get as many pieces as possible for the weight I will charge, sending them wet, you would pay the same for half of the pieces and I don't want that, I may charge a few dollars more per kilo for the electricity I'm using drying them but in the end, you will be still far ahead, in time it will dry naturally but not for some months...!
Cheers
George
Hi Wayne,
Cheers
George
Wayne
G'day Wayne,
This evening I cut a bunch of blanks of approx. 1" 1/2 square x 4", a few a little less but I tried to make them up in pairs from both of the burl hollowed edges and the spalted wood. They were the wettest pieces, particularly the spalted ones so, and I mention in my previous post, I have them all in the oven for and overnight and possible an old day "cooking":smile:
Is not easy to get pieces 1" 1/2 square x 4" with the hollowing all thought the pieces, most of the burl hollowing happen/is within 1" or so from the edge, some eyes can go deeper but they go in clusters as the bowl shown on this thread shows well, the eyes formations after a certain depth are very irregular but, you have beautiful pieces in these, you take how many you want...!
I'm expecting 1kg of dry Peppercorn burl to fill a good size box.
As for shipping, that is the simple part and goes like this. Note that Australia Post has increased the International shipping prices to;
* 500gr weight = AU$16.00 shipping only
* 750gr " = AU$20.00 " "
* 1kg " = AU$24.00 " "
* 1.25kg " = AU$28.00 " "
* 1.5kg " = AU$32.00 " "
...And so on, each 250gr increment after the firts 250gr, which cost now AU$12.00 instead of the AU$10.00 previously, it will cost approx AU$4.00 and I say approx. because the values are not ending in exact dollars but a few cents either way.
Cheers
George
Yeah mate, I'm glad I put a smile on you...!:biggrin:
Today I cut a few more of the pen blanks casting pieces and cleaned up the bark on every piece I could that was it that first box, some it come out easy some need some "bashing" and some ain't barge so, those will be for the Aussie members that may be interested, the bark on them is not a problem then.
This doesn't mean that, if any of you want them with bark, I can send them but, I will not be responsible if Customs don't let them in into the Country, your risk.
I wanted to take some pics of the Colonial Red Gum pieces and some others but, I never had the chance today, I have a bunch of boxes that have to come out first into the open but not when is raining, no sir...!:frown:
Will see what happens tomorrow.:smile:
I leave you with a pic of the third box of the Peppercorn burl that I didn't show the other day and they are all from the very spalted (no holes) pen blanks I cut to dry, these will make some stunning blanks stabilized either in clear Juice or with some dyes...! These are also in the oven so that I can weight them dry and start to get things organized...!:wink:
Nearly there...!:biggrin:
Cheers
George
Guess I should get a couple pieces for pepper mills as well , seeing as how they are from a peppercorn tree , about 2 1/2 square by 8-9 inch should do . Am I correct in thinking that these are from the S American peppercorn tree , which has become a weed in Australia ?
Don`t worry about non-uniformity of the voids in the blank . Only once have I found a 1 1/2 inch plank with insect holes that very uniform throughout . I think a cylindrical object looks best when it has a variety of features around it - the thrill of the unexpected , because you can`t see the other side until you turn it around .
Wayne
George I would love a box or 2 I have bought olive wood from you in the past and it was beautiful. Would not mind some of that root burl. Be interested in the one kg size box I understand postage will be 24 AUD more or less. Thanks for this amazing opportunity.
Ed
Wayne
Yes, you are correct Wayne.
Do you want some of these big pieces in the spalted stuff or with the holes? (possible each piece will a combination of both...!)
Cheers
George
Ed
Yes mate, that is correct.
I believe you are referring to.pen blank pieces, right?
Cheers
George
Wayne
Do you want some of these pig pieces in the spalted stuff or with the holes? (possible each piece will a combination of both...!)
Cheers
George
Combination would be great George , if possible .
Wayne
Cheers
George
Got 4 pairs cut and in the oven...!
Cheers
George
The pic of the regular peppercorn burl pieces looks good too. This could be expensive...! I am anxious to see the red gum pieces too, along with the other types.
Don't worry they are coming...!
This evening I took from the oven after 24 hours drying, only the pen blanks cast pieces, they did dry faster because of all the holes and the sizes they were cut at, all other are still there + the bigger blanks for Wayne.
So, I now could work out how many pieces approx, I can put in a 1kg box and also on the 2kg box, I can gi bigger it necessary.
I have attached the pics I took, they show a 1kg box filled to limit and the same for the double size box with 2kg of these same cast blanks.
The 1 kg box I can fit between 35 and 40 pieces and on the 2kg one, about 75 to 80 pieces, they are all different and some weight more than others.
So, this is only for the Peppercorn burl cast pieces and the costs are as follow;
* 1kg box with Peppercorn burl cast pieces only, AU$30.00 + AU$24.00 shipping to overseas destinations.
* 2kg box with Peppercorn burl cast pieces only, AU$60.00 + AU$40.00
* For within Australia, the price per kilo is the same at $30.00 + freight that will be $9.00 for a 500gr Postal bag and $14.00 for a 3kg Postal bag, a 5kg postal bag will cost $19.00
Prices for the other wood species prepared as pen blanks casting trimmed pieces, I will work out very soon, some of those species are heavier so, I need to work out a price that will balance their extra weight compared to the Peppercorn and allow a similar number of pieces for the same value I have given above.
Tomorrow, I will be able to weight and box the full size pen blanks from the Peppercorn burl those with holes and those spalted no holes, I hope to be able to maintain the AU$30.00 per kilo.
Have a look at the pics and remember that, I can make a mix package with any of the wood species I will make available to you guys, that will be no problem...!
This should start to give you guys a very good idea of what it will cost...!
Cheers
George
That 2KG mixed box is tempting! It would be cool to have a large assortment of casting pieces (probably around 40) and then the rest filled with mixed species of burls including red gum, peppercorn, olive root burl or whatever you find interesting and surplus that you were thinking of including with this deal.
I like the looks of the peppercorn burl blanks and I have never done olive root burl or red gum, so it makes sense to me to go for the gusto and get a large box! You only live once!
Spalted with no holes, I think for the peppercorn burl. Maybe a few with holes that I could cast, but sometimes I don't like the looks of the wood with holes or anything that looks like banksia pods. Kinda weird to me!
Here we go...!
OK folks, I have most of the stuff done for you guys to pick and decided quantities.
I may add a latter stage another couple of casting tree species pieces such as the Vine, Truffle etc. but for now, this will do.
All blanks are identified with the prices included, for a mix match of pen castings pieces, you select how many pieces you want from each, as a couple of pics attached demonstrated, each bundle of 6 pen casting pieces weight between 200gr and 250gr, depending of the wood species so, the total number of pieces requested may require a slight adjustment in numbers, to keep the weights withing the 250gr increments, including the packaging stuff required.
I believe, you guys have everything you need to make your selection and order, thanks...!
Have fun...!:biggrin:
Cheers
George
George,
I'll take the following (to the U.S.):
1 KG of peppercorn burl casting pieces $30
6 pieces or 250 gr of #9 red gum casting pieces $5
6 pieces or 250 gr of #22 olive root burl casting pieces $3.75
6 pieces or 250 gr of #30 bottle brush casting pieces $5
6 pen blanks of peppercorn burl spalted $6.30?
This will be shipped to the U.S. which I think you said would be about $40 AUD, so it looks like it will be around $90 Australian. Check my math!
And as far as the casting pieces go, I like a ragged edge with peaks and valleys, so to speak . Generally, the more chewed up the edge, the more I like it.
Lewis
Thought I had modified my post hours ago, but for some reason it didn`t stick . Add 2 1/2x 9 20 A&B and 21 A&B . My contribution to your Australia Post commitment .
Wayne
Gotcha mate, I will put all the 2 lots together and let you know correct costs, Thanks.
My Australia Post commitment is in a big risk of not being renewed after September (contract annual renewal time), they may consider that I'm too small to allow such a cash account for a discounted rate for International destinations and if that happens, I'm fried to send anything overseas.
So far, I have complied with the minimum of AU$5,000 annually for International mail/freight charges, that has been the one condition that I have made sure I would comply even if many of the orders sent, I made nothing, however, Australia Post has recently changed considerably its policies and I have heard a rumor that they are considering to abolish these old type accounts so, I'm concerned, will see.
Every parcel I send overseas will help to hopefully keep the account going...!
Cheers
George
George,
Lewis
Hi Lewis,
I just got home and saw your order so, I will get it all together and confirm costs with you.
I have took note of all your requests:wink::biggrin:
Cheers
George
Wayne,
I have your blanks in a box and it is about half full, because the boxes sizes between this one and the one smaller one is a big difference and off-course, one is not big enough and the other is too big,
I can fill it up with paper but you may want to use this opportunity and put something else in it to make the shipping worthwhile, up to you.
As is the box weighs 4.7kg a cost of shipping of AU$75.00 you can add another 1kg for an extra AU$16.00 it will all depend on what would you want to add for me to give you the total, as you should already know how much as the blanks you ordered will cost you, huh..?:smile:
Lewis
Pretty much the same with your order, I have to use the same size box and as you can see in the pic, is a lot of room in there so, you may want to add something else, the total box shipping cost is AU$45.00 (2.38kg) a few grams extra from the box containing the 1kg of Peppercorn burl pieces, some extra blanks thrown in + the weight of the bigger box.
Again, I can fill it with paper or, you use the opportunity to add something else...!
Let me know, please...!
Cheers
George
Wayne,
Might as well add 22A&B and 23 A&B . Do you have any red gum in about 1 3/8 square 3-5 inch long ?
Just looked at your website . Are the #1,2 &3 pieces of red gum burl 1 1/4 inch thick ?
Wayne,
Yeah, I though you were thinking red gum burl or Colonial/red gum root...!
Each slice has its dimensions, 1" 1/4 are most of them...!
Cheers
George
I'd like to have 1 of the following (if you have anymore of the first two selections)
Australian #90z (diagonal cut) Tree of Heaven wood - PEN blanks - Sold in packs
Batch-12 - #45 Dwarf Banksia 1/4 pod cast - sold seperately - 11 availabe @ AU$6.00 each
250 gr of #26 Platypus gum burl carved by termites
