Pen Box voting
You may vote for 1 of the 11 boxes
  • Box 1
    Votes: 10 6.4%
  • Box 2
    Votes: 11 7.1%
  • Box 3
    Votes: 1 0.6%
  • Box 4
    Votes: 11 7.1%
  • Box 5
    Votes: 3 1.9%
  • Box 6
    Votes: 2 1.3%
  • Box 7
    Votes: 99 63.5%
  • Box 8
    Votes: 4 2.6%
  • Box 9
    Votes: 1 0.6%
  • Box 10
    Votes: 3 1.9%
  • Box 11
    Votes: 11 7.1%
  • Total voters
    156
  • Poll closed .
Monty
Group Buy Coordinator
Pearland, Texas, USA.
We have 11 excellent entries in the Pen Box Contest. You may vote for your favorite box. The top 5 will advance to the final voting.
Box #1
The box is made from walnut veneer with a Gator back paper. The sides(box)made from 2" solid wood wheel and adhered to the veneer with double sided tape. The catch (lid closure) is elastic ribbon that secures to the wood button for easy closure. The total weight of the box is under 20 gram. Holds up very well despite the delicate nature of veneer.
Box #2
Tell us about your entry: Xtreme snap fit pen box. All crosscut segmented construction.Made from Zebrano and Panga Panga.They are both very porus woods,I like the effect so I tried to highlight it.The bottom has a blue/black resin center with an inlaid segmented rimgStarted with a 8 stave blank then cut and sptral stacked the disks.the center was made from some of the leftover blank sandwiched between the 2 woods.the inlay rings were also cut from the base blank.The finish is thin flex CA.
Box #3
This pen "box" is an oak cylinder with mahogany end caps. The cylinder sits on a base of oak and walnut. One end cap is glued and the other is held on by friction and pops off to reveal the pen.
Box #4
Made from a block of cedar. Using a torch to get a burned/aged look to simulate a buried treasure chest to house one pen with a similar theme. Cedar was shaped and cut on band saw and then I used a forstner (2") bit to hog out the body of the chest. The box was mated with black stamped out hinges that were purchased along with clavos (nails)to give the appearance of an old/weathered treasure chest.
Box #5
This box was inspired by the Timberbits YouTube videos. It is spalted maple with a walnut lid and snakewood handle. The interior bottom is fiber flocked and the box was laid out for continuous grain pattern as you turn the box.
Box #6
This box was inspired by the Timberbits YouTube videos. It is curly Koa with a curly Maple lid and Amboyna Burl handle. The interior bottom is fiber flocked and the box was laid out for continuous grain pattern as you turn the box.
Box #7
The box is made from Hawaiian Curly Koa and Gabon Ebony. The exterior features a hand rubbed lacquer finish which surrounds an interior carefully upholstered in plush imported satin. The design is elegant...intended to compliment the "best of the best" high end pens...so the cushy soft interior will accept the largest of the component-set pens, but will also provide a suitable home for "Jr." series pens. Consideration was given to ease of use: the interior space and shape invitingly allow the pen owner to easily grip his or her pen when removing it from the box. A pleasing design note: a set of nearly unseen hinge stops were utilized to restrain the lid at an attractive angle when open, rather than allowing the lid to "plop" fully down to the desk surface.
Box #8
Maple with walnut ends. I drilled and turned the outside of the box, then drilled and turned the inside of the box and made a cut out for the pen.
Box #9
I started with a plain board and routed the pen slot by setting up a jig with stops and used a plunge router to deepen the groove slowly because of the size of the router bit. Then applied Leopard wood veneer dyed Black.
Box #10
I started with a board cut to size. Routed the pen groove with a plunge router and a jig with stops. Then cut the free form front and flocked the pen groove. Finished with poly and steel wooled to kill the shine, leaving a warm feeling finish.
Box #11
This Pen Case is made from a 10 " piece of a Black Locust branch. Pruned by Arborists and left on the ground, the bark had fallen off exposing the Bast of the branch which is the first layer beneath the Bark. Groves were cut on the table saw to hold the pen. The lid to the box and base were lightly sanded to blend in the sides that had been glued in place. I left the top of the box Natural showing the cracks from years of being exposed to the weather. The inside was solid. Picture hanging pins were used to create a pivot point through the sides of the top into the base to allow the lid to open and store your favorite pen. The first photo is taken vertically to the show detail of the finished lid. A light coat of oil was applied to the box as a finish. Overall Dimension 2" x 2 "x 7" .
Oh this is exactly what I was waiting for and not disappointed one little bit. here is a contest that will stay for sure. I can actually say this will be the hardest contest to pick a winner that I have seen here. This is up my alley. The thinking outside the "box" is evident here. All the players should take a bow. I hope to see this kind of thing throughout the year and not only for contests. This is what distances ourselves from just pen turners. Put that special pen in there and the price goes up.
Love it. Good luck to all. Going to have to study this one. :smile:
GREAT! MORE decisions to make :rolleyes:
Take your time Chuck....We understand how hard it is for the "older members".
Those senior moments do take a moment to remember what you were doing.
Wonderful workmanship and thinking went into all the entries. But I have to say for me, it wasn't that hard to see the one I liked the best. Maybe I am just easy to please.
You are all winners here. Congrats to those that move ahead. And to the ones that don't...........This is all about personal taste. You have done something special this first year of this contest.........you have set the bar very high.
I noticed that there is a pause in posts to this thread, perhaps because it has fallen way down the viewing priority since it was posted. These boxes deserve plenty of attention. The extensive creativity is the thing that caught my attention: there is such an array of literal "outside the box" design approaches that have been so artfully produced! Great work by all who participated on this contest.
Just about 1 1/2 hours left to cast your vote.
Come on, lets vote. We've had 912 views and only 155 votes? I don't believe that everyone has looked at this thread 8 times.
