Cleaning oil/grease from old metal tools
Jim Smith
Lakeland, FL
I happened across an estate sale in my neighborhood and picked up a large number of tools like a very nice cross slide table with a tilting vise ($35), a couple of other machine vises ($3) and several large old steel C-Clamps ($3). All of these tools have no rust at all but there is old oil/grease buildup on them. I'd like to clean all of them and grease them up before I put them to use. My question is, what is the best way to clean the old grease/oil from these tools? I was thinking of soaking them in a (solution?) before drying them and lubricating. What are your recommendations of what to soak them in? (hopefully other than gasoline) Thanks for any suggestions you have.
Jim Smith
i'm old school and like Varsol (Stoddard solvent), similar to the mineral spirits suggested above. Generally cheap at an automotive store. It leaves a slight oily film on the metal that helps slow rusting.
I like Zep Citrus Degreaser. A gallon is about $10 at Home Depot. I used it almost straight for heavy grease. I recently disassembled and cleaned an old bench vise that was caked with gunk and it worked well. In that case I cut the Zep with a couple quarts of very hot water, then I soaked everything for a couple hours. I rinse with water, but immediately used compressed air, then WD-40 to displace the water and leave a little film.
EDIT: The Zep doesn't dissolve the grease, you need to persuade it off with a stiff bristle brush.
Zep is great stuff. I repair clock movements, some of which are covered with stiff oil and grease. I soak the movements in mineral spirits to soften the hardened oil and grease and move them into an ultrasonic tank filled with full strength Zep De-greaser. They come out bright and shiny. Yes, Zep is a wonderful product.
If you are up to soaking it, kerosine is a good choice. Cheap, and leaves a layer of lubrication without another product.
Kerosine was every farmer's solvent of choice back in the days before WD-40 and all the fancy stuff we have now. It's still a great, simple & cheap product for cleaning metal parts. Perhaps a bit on the smelly side, but quite effective.
