JD Combs Sr
You may have seen my 1st knife, it's not noted as such in the original thread but I call it "Beauty" as opposed to my 2nd knife which was posted as the "Beast".  If you saw one you probably looked at both.  In any case here is #3.  I made it from a blade that was originally purchased for the Beast but it had a couple slight defects on it that I didn't want to give to the customer that commissioned the Beast.  The blade is still very serviceable so I used it to make a knife for myself.  Take a look and let me know what you think.
Here is a pic of the most obvious of the defects. It is some slight separation or de-lamination of a layer in the Damascus steel. Look at the wavy line at the lower left of the blade portion. The other defect starts about the center of the blade and is evident from there to the right but is harder to see. There is a series of grinding "waves" in the steel as if the blade was chattering slightly while being ground.
Given the defects this is how it turned out. Using one of my pen stands to display it vertically.
A horizontal view
A close up of the finger guard.
Top view, note the dog leg:biggrin: in the antler handle.
Hold off commenting for a moment, I will continue the thread in the next post. Got a bunch of pics of my process.
A horizontal view
