JimB
Does anyone have a source for the individual clear boxes? The ones I see at CSUSA and PSI seem small and appear they will only fit small stoppers. Thanks!
The CSUSA boxes are 1 7/16 square. How big do you want?
The 5" tall ones are good many times but I like making the teardrop style and those are 2.75" so it only leaves about 2.25" for what I turn. I was hoping to find a box that is a bit taller.
Jim I am sure you seen the Penn State ones as well. They are about the same and they also have the cheaper tubes. Those are less room. Those show the teardrop stoppers in them. You can always go with a jewelry box type thing and maybe find one with a clear lid if you are after clear to show off for display. I do not have a link but a google search may find something. Just keep in mind making them too tall is not a good idea because if people want to put in a refridge they may not fit. Good luck I have nothing else for you. Also being the stopper will be on a slant in those boxes you do pick a bit more room. Good luck.
