10.5mm Cutter With Slight Rounded Corners?
Fireengines
Plano, TX
I received an email from AZcarbide today asking me if turners would be interested in a 10.5mm square cutter with very slight rounded corners just enough to eliminate the sharp corners? Your thoughts?
I used to buy from him when I used carbide. I found his cutter to compatible with EWT if that helps anyone.
He already has an 11mm R2 and a square 10.5 mm cutter, so if I understand his question correctly, it seems that he is considering the addition of a 10.5mm cutter with something like an R4 or R6 corner to his product lineup.
Personally, I probably wouldn't buy such a cutter. I don't use square cutters at all and I'm perfectly happy with r2 cutters, so I don't see a need for something between r2 and square, particularly in this small size. Others might though.
