VotTak
Does anyone uses epoxy resin? Which brand? If you use it to cast worthless wood - is it better or worse than alumilite? I was searching forum but did not find anything.
			how do you remove bubbles?
 ). You can even buy specialized epoxy resin mixers that will combine the resin and hardener without introducing bubbles.
). You can even buy specialized epoxy resin mixers that will combine the resin and hardener without introducing bubbles. .  Given the right formulations time isn't an issue with the stuff so 7,8,9,10 -100 color pours  wouldn't be a problem,,,,the skies the limit.
.  Given the right formulations time isn't an issue with the stuff so 7,8,9,10 -100 color pours  wouldn't be a problem,,,,the skies the limit. Removing bubbles ......
Use overpressure ... By using a pressure pot and higher atmospheric pressure, you DO NOT REMOVE any bubbles from the mix, but since air pressurizes and shrinks more than liquids, the bubbles trapped in the mix can get very small and pretty much unnoticeable. As I said, it won't remove any bubbles, it just makes them smaller. If there are a lot of them, they can appear as a haze floating in the finished casting... This method is much more prevalent in castings that have a more opaque look to them.
Michelle, I am also wondering what is your response to VotTak, post #7. I live on a small island where it is difficult to get PR (no local hobby supply, and regular "hazardous shipping" is prohibitive due to location, etc.). The moderate to high humidity makes Alumilite a challenge, since the stuff goes bad just sitting in the bottle in the humid environment.)
All that said, I am thinking that your epoxy approach might be my answer. Thanks if you have any suggestions.
Use heat to make the epoxy mix much more liquid, allowing the bubbles to rise out of the mold ... preheating the mold helps as does pouring the epoxy in a manner that reduces the air trapped in the mold.
Use vibration to help make the bubbles rise ... set your filled mold on a vibrating tumbler or some other vibrating tool to help clear the bubbles out of your mix before it sets.
Use negative air pressure to make the bubbles bigger, which will help them rise out of the mix ... This is a vacuum setup. You can combine this with other efforts to help move those bubbles out of your mix before it sets.
Use a push stick ... visible bubbles can be removed manually by taking a thin stirrer or other item to reach into the poured mix before it sets and pushing bubbles away from the items cast within. Generally a last resort, as it can leave "tracks" through the clear resins or introduce other contaminants.
It seems that everyone likes to make extra work for themselves. I have never used heat I've never had to worry about the temperature in my workshop when I cast with epoxy resin. I simply gently mix the two together Epoxy and Hardner. pour it into the mold and place in the pressure pot at 50 PSI for about 8 to 9 hours. When I remove it from the molds I do not have any air bubbles. No need for heating or vibration whatsoever. West marine epoxy and hardener products.
West System epoxy, as with most other epoxies will yellow over time. I know this first hand. I have done a lot of work with West System as well as System 3 epoxies filling voids in Mesquite for flat work and have also cast it for pen blanks. My front doors on my house are all mesquite and they both have a large crack that runs all the way through that was filled with clear West System epoxy and it has yellowed a bunch. I have a solid, clear epoxy test blank in my shop and it has yellowed quite a bit as well.
That said, once the pen is turned, the thickness of the epoxy is thin enough that you will not see the yellowing in most cases.
So does adding pigments or pearlex powders cover up the yellowing? In other words if I'm coloring the epoxy resin is there any need to worry about yellowing?
Pressure does not shrink the bubbles, none the less it does reduce them. Rather it makes the air that causes bubbles go into solution similar to a soda bottle. On the shelf, there are no bubbles in soda due to the pressure in the bottle. Remove the cap, release the pressure and bubbles appear. A simple calculation using the gas pressure law where pressure and volume are inversely proportional will tell you that at the pressure we use to cast, the volume of a bubble couldn't really change that much. A 2x increase in pressure only decreases volume by 1/2. Since the volume of a shere is proportional to the cube of the radius, you wouldn't see much of a change. Still works, just wrong theory.
