Drewboy22
I will start this with a statement of ownership! I OWN THIS MISTAKE! I got moving, I knew what I was doing, and didn't stop to double check... ALWAYS DOUBLE CHECK!!
I am working on my Christmas Gifts and for the Ladies I will be making the Designer pen. I cut, drilled, glued, and reamed/flushed. I put the bushings and blanks on the mandrel and started knocking it down. 2 hours later- turned, sanded, CA'ed, sanded, CA'ed, wetsanded and polished... I went to press the pen together and as I was pressing in the twist mech. I noticed the lower barrel seemed kinda short. Sure enough - I had the barrels switched on the lathe, so the long barrel is on top and the short is on bottom.
DOH!!!
DOH!!!
