Jgrden
Is there a electronic speed control that can be plugged into the outlet and then the lathe plugged into the variable pseed box?
No.
The standard AC motors are constant speed. Universal motors like you find on sewing machines and routers will use the cheap variable speed controllers, but those are fast motors with low torque.
DC motors with rectified speed controls is what you had on your Jet 1014.
There are brushless DC motors used on the bigger midis now, and 3 phase motors with variable frequency drives are used on bigger lathes
No.
The unit I am looking at is Harbor Frieght #65345, 7.5 Amps., 1/2 H/P, Single Phase, 110V/ - /60 Hz. Would a speed control work? they call it a Router Speed cntrol #43060 at HF. ??
Ken:No.
John - that speed control works on,universal motors. It will not be successful with a fixed speed AC motor which is normally used on the non-vs style midi lathes.
If you put a router motor on the lathe, that would match it. You probably would not be a happy user though.
Look for a used wheelchair motor and controller to have a low cost DC system, or a repurposed treadmill motor-controller combination.
Ken:No.
Thank you for your input. You saved me from making a mistake. I am going to explore the wheel chair motor but think it might be best to bite the bullet and find a used 1014VS used or buy a used 1014 and upgrade it. T"he new 1015 VS makes the pen turner change belts for the different speeds. Doen's this seem like a bother to stop the machine change belts??? Am I missing something?
Oh ... so they went ahead and made it a hybrid speed control system?
In order to change speeds to get the full range that lathe can handle, you have an adjustment knob to change the speed of the motor itself, and you have pulley wheels to act as a transmission to change the lathe spindle speed on top of that...
The little HF VS Mini Lathe (8 X 12) has no belt change. All done with the potentiometer.The only lathe I'm aware of with no belt change ever is the nova dvr.
well there you go.The little HF VS Mini Lathe (8 X 12) has no belt change. All done with the potentiometer.
I went to Woodcraft to look at the 1015 VS. changing the belt is not what I want. i did consider going to the manual but it is not for me. I was s[poiled by my 1014VS. Thank you.Ken:No.
The 1015 VS has 3 ranges. The top range is from 600 to 3600. For me I wouldn't need anything outside that range. Are you sure you didn't look at the non-vs model?
The Jet 1014VS is a belt changer as well so I'm confused by why you think the 1015 is different. I have the 1014VS so I know it is a belt changer. Perhaps when you had it you just never felt the need to change the belt setting with the range the VS gave you.
The 1015 comes in a VS and non-VS just like the 1014 did.
I'm not trying to give you a hard time. I just don't understand why you believe the 1015vs is more of a belt changer than the 1014vs.
John -- my 1014 VS does have three wheels -- but I use the middle one for most everything that fits the lathe. I seldom (as in never in memory) change belts -- just work with the range.
There are lots of users here with the turncrafter from psi. I have no personal experience.
If I was looking for a new lathe and could wait, it would be when the rikon EVS model goes on sale for $500 and change.
You can also take a look at the nova comet 2. Woodturningz carries it as well as other online vendors.
