A Perfect Mistake
See more from jcm71
jcm71
Chattanooga, TN
Before gluing I dry tested the fit of both tubes in this Perfect Fit. They were a little snug, but no more than I have successfully glued before on PFs. Alas, on both barrels the tube jammed before being fully inserted and I couldn't press them in. The fix on the lower barrel was a small piece of scrap antler. On the upper barrel I had to trim the protruding brass down to correct length before pressing on the center band. The top barrel is a little short, but the pen works like a champ. I think I'll charge $10 more than I normally do for these, just because of the aggravation. BTW, Buckeye Burl with CA finish.
