.9 mm Pencil
Mr Vic
Falcon, CO
Had a customer toady who's interested in a pencil of either Turquoise True stone or Cholla Cactus with Turquoise inlay...
Kicker is he wants it in .9mm which I'd normally dismiss but this could be a $100 sale if I go with the Cholla. A slim line is two small and it needs to be chrome to complement the Turquoise...
Wondering if I could get a Pentel and swap the guts with something like the Stratus or Wall St II pencil kits.
mlconnelly
Spartanburg, SC
I got the Pentel conversion mandrel from John Grounds and have used it to make several pencils including a 0.9 mm. You can find everything you need to make the conversion including the step drill bit on his website here (The Perfect Collection).
IWC
Lynchburg Virginia
alphageek. That is an interesting conversion, any info on how to make it happen? Will it work on a twist or just a click. I have 2 segmented pens with reverse wood sections, I have a customer to buy them if I can convert it to a pen - pencil set.
alphageek
Former Moderator
Green Bay, WI, USA.
It's my understanding that it can be done with a twist (twist to let the lead "loose", twist back to stop). However, I've only done them as click and it's been a while. For a long time I just did the pentel conversion stuff. I'm hoping there is others who voice in on using the details.
  • Like
Reactions: IWC
TimS124
Asheville, NC
Give the Woodturningz.com folks a call...they list a cigar pencil in gold that clearly states it uses .9mm lead. They also list a cigar pencil in chrome (the color you requested) but it doesn't state what lead size it uses....given that the part numbers for both kits differ by only the trailing letter (with the chrome one having and extra "C" on the end...implying "chrome")....I would expect it's the same.
Price is under $8 unless you order at least 10 kits (then you're down to almost $7/each).
Here's a link to both versions so you can compare for yourself: Cigar Pencil Kit - 24kt Gold - WoodTurningz
Cigar Pencil Kit - Chrome - WoodTurningz
Mr Vic
Falcon, CO
Alphageek . . . For what ever reason the link to Exotic's brought up some sort of pen last night and I was thinking...what the??? It's going to the Schmidt converter now and it should do the trick if depending on size pen desired.
Thanks TimS124... Gives me another option dependent on what type "pen" he want to convert he wants
ed4copies
Local Chapter Manager
Racine, WI, USA.
Hi Vic,
I have not, personally, used the .9mm. So, I can't give you "step by step" instructions.
I know the standard size nib on many pens has to be enlarged, due to the size of the nib to accommodate the .9 lead. The actual size of the nib that must emerge from your pencil design is .115".
Hope this helps, sorry I have never done one!!
Ed
Mr Vic
Falcon, CO
Ed, Was thinking of a Black Titanium Wall ST II Elegant...Very Similar to your Sierra Elegant if not the same of a different name. If you have a spare moment between checking in inventory could you check one... If it fits I'll have a single source as opposed to multi sources and hoping they blend..
ed4copies
Racine, WI, USA.
Vic,
The .9mm will not just "slip in". You will have to modify the nib on the pen.
I would buy a couple chrome sierras and a couple .9mm inserts and get the concept to work, then modify the real pen you plan to sell.
I view these components as "toys for those who are tired of just a kit".
Experimentation is the best way to find what works.
Yes, the Wall Street series are made by Berea, so we do offer exactly the same pen, a little lower cost. But, you have to wait for the mailman:eek::eek:.....bummer!:frown::frown:
IWC
Lynchburg Virginia
The Schmidt DSM 2006 Pencil Mechanism .7 worked great ! Turned my pen into a pencil with just a quick length trim. The pencil mechanism with the twist pen works perfect.
ed4copies
Racine, WI, USA.
This is true for the .5 and .7mm versions.
The .9 won't fit through the "stock" nib hole.
