triw51
I purchased a new banjo for my 2nd hand lathe.  My problem is that it does not slide smoothly when I am positioning it.  I cleaned the rod inside with carburetor cleaner to remove the packing grease and used a silicone dry lube for lubrication.  But after a while that gummed up and I had to clean it again this is like the 4th time in less than a year.  What do you use to lube your banjo with?
I do not know the technical name for the parts but I am referring to the locking parts that has a metal ring that slides on an offset rod.
Thanks William
Thanks William
