Difficulty with Silmar
stuckinohio
Columbus Ohio
Hello,
I started out using alumilite water clear and had great results,then went to alumilite clear and also had great results. Of course I am going through resin quickly and alumilite is expensive, so I decided to change to a different type or resin.
I bought a gallon of Silmar 41 and started using that. Wow, what a difference and so much more difficult. I'm having a big problem with color bleed/mixing. Also can't get the hardness thing right.
I was used to alumilite heating up so I know when to pour and keep the colors separate. This silmar doesn't heat up until long after it's already poured. I have been waiting for it to get a little thick,then pour but it takes forever to thicken and when it does, it goes straight to too thick
I first tried 10 drops of hardener per 1 ounce or resin,but that took three days to harden. So I tried 150 drops for 8 ounces next time, but I still can't get the whole color mixing thing.
Any tips?
Silmar 41
I use but 3 drops of MEK per ounce? I preheat the Silmar in a cup in a Ultrasonic jewelry cleaner from Harbor Freight. I stir for 2 minutes and then add the hardener and stir another 2 minutes to mix thoroughly then pour, no problems here with this procedure. I do not use a pressure pot but I do vibrate the full mold on top of a old grinder with a unbalanced wheel . Good luck..Jan
150 drops per 8 oz!!! :eek::eek::eek:
I use 4 to 7 drops of mekp per oz. With my schedule, I pour my blanks and take them out at the same time the next day and they're ready to turn.
On pouring with colors, I wait for the resin to start to gel, about 10 to 12 mins depending on how much mekp I've added, then pour.
Harry
If you are using Alumilite dyes, that's your problem. PR uses different dyes. Mica powders work, but don't all cure at the same rate. I use dyes from US Composits for Silmar.
I use 4 drops per ounce. I try to pre-heat my resin up to about 80 degrees. At that temp, I pour at about 16 to 18 minutes. Different colors react differently, so more or less time is needed. I had some troubles when I went from PR to alumilite. Each has it's own learning curve.
EDIT: I also use a timer to make sure of my timing.
Ahh. I am using alumilite dies as well as mica powders! I guess that's the problem. Thank you for that!
Hi Bob,
..are you using a infrared thermometer to check the temperature?Thanks..Jan
I will also try heating up the resin before hardener is added too. I'm happy to know about the dye for sure. Now I have to wait to get new dyes!
If mica causes problems, what is recommended to achieve the metallic or pearl look?
Thank you everyone for all the good answers also. I appreciate it.
I don't know what the columbus idea foundry is, but it sounds promising! I'll check it out. I have some good ideas, but not much skill.
Hi Bob,
No, I've thought about it though. It's really just a rough estimate. I use a heater during winter, and I put my resin out in the warming garage about an hour before I pour. In the summer I put it out about 30 minutes before I turn on the air. My garage rarely gets below 75 with the air, so the resin stays in the 80 degree range. Scott has used those thermal strips a few times, but it's more trouble than it's worth.
The next time I see one of those infrared thermometers on sale at HF, I may pick one up. And thanks Mark for the compliment.
Just a random comment...
Jan, Bob and Harry - kudos to each of you. We b..tch about folks not answering questions/or being polite... But each of you gave very helpful suggestions! We also need to acknowledge stuff like this!!!
Oh, I have no help to offer - sorry!!! :smile:
Thank you Mark
When I first joined the IAP, I didn't ask questions because I seen others asking a question and get a reply that was either rude, or a person would take the time to type a sentence that made a newbie feel embarrassed or incompetent for asking, when in that time frame could of typed "this is how I do it or this is what your doing wrong".......or just kept his thoughts to them selves.
Sorry didn't mean to hijack or steer this in a different direction.
Ask anyone that KNOWS me, I'll give and help anyone, just have to ask.
Harry
