cmccarter
Can anyone verify that the triton fp uses the following tubes. The Library referances do not include the triton.
cap 12.5mm x 1.9"
lower 10.5 x 1.85"
tia
cap 12.5mm x 1.9"
lower 10.5 x 1.85"
tia
cap 12.5mm x 1.9"
lower 10.5 x 1.85"
tia
cap 12.5mm x 1.9"
lower 10.5 x 1.85"
tia
Same as the Atrax, so I think
Cap - 1.9"
Lower - 2.19"
I've been swapping out both recently.
cap 12.5mm x 1.9"
lower 10.5 x 1.85"
tia
Cap - 1.9"
Lower - 2.19"
Actually, Mark, the Atrax body is longer than the Triton (with the supplied tubes). Yes, you CAN make the Triton on Atrax (or Junior series) tubes, but you have to change the spring on the rollerball--it needs to be a little longer. If you are making the fountain pen, no modification is needed.
FWIW,
Ed
