Dust Collector Bag
WriteON
Florida & Pa
When the bag needs servicing (empty, clean)...do you empty and reattach it or do you wash it......or do you replace with a new one. The 1 micron on my unit is due. Thanks, Frank
At what point does the bag get replaced other than damaged or punctured. Mine seems to be leaving a white dusty film on the floor under it.
Are you sure you don't have a small leak around the filter or the collection bag? Under advice from a local woodworker when I set up my DC I used I thin strip of adhesive backed weather stripping where both attach and are clamped to aid in sealing.
When it leaves dust around, you either have a poor seal around the rim, or the particle size is less than your 1 micron. No guarantee on those bags and particle size either. I don't imagine they ever need to be replaced unless you want to get finer bags.
What is a finer size. Is 1 a good standard? I don't mine replacing the bag ...but I will check the seal first and inspect for any visual damage. Thanks
