BOW Jr. Gent II Rollerball
See more from bgio13
bgio13
Oak Bluffs, MA, USA.
Ti/Gold Jr. Gent II rollerball pen dressed in Bethlehem Olive Wood. Finished using my Rustoleum OMWB dipping method. Thanks for looking,
Bill
Glorious Pen, Bill.
Love the Subtle Smooth Finish, of your Rustoleum Drip Finish, it so Compliments the Ti/Gold of the Pen.
Your Fit and Finish is Superb.
Great Photograph too.
Congratulations,
Brian.
Thanks for the compliments. I wanted a little more subtle finish on this one, so I didn't polish the blank as much as I usually do. There is some shine there so you know there is a finish, but didn't want to overpower the finished pen. Thanks again,
Bill
i am going to try this on a set that i am doing for my preacher as a thank you gift for doing my wedding in march. can it be put on while still on the lathe. i have done a poly finsh this way i put a coat on and let it dry overnight and then keep doing it till i have put on about 6 or 8 coats over a few day can i do this with the omwb. thi same way
thanks for the info
thanks for the info
Todd, this tutorial in the library by Les Elm describes the method of finishing on the lathe.
http://content.penturners.org/library/techniques/minwaxfinish.pdf
I have tried the method described in the tutorial using Enduro and the Minwax products, but I always ended up with ridges in the finish I could not sand out. I have not tried this method with the OMWB finishes, but there is no reason I see why it wouldn't work applying it on the lathe. I have found that dipping works for me in that I sand a lot less, and no ridges. Try it and let us know the results. Hope this helps,
Bill
