Pens By Scott
Just wondering if anyone has any opinions on the Sierra Click Pens and Click Pencils?
I have a client looking for Christmas gifts for their customers.
I haven't done any of the pencils, but I've done quite a few of the pens. The mechanism seems to hold up well, and it's an easy kit to assemble. The biggest issue seems to be with the spacer that you need to use if you want to use a Parker style refill. Customers lose them the first time they take the pen apart. One solution is to shorten the tube to 1.88". You can then use a Parker refill without the spacer.
Unshortened,this kit can use the G2 roller ball refill. If you shorten it, you lose this option.
You can trim the spacer using a disc sander or grinder to what ever length you need. You can also just make a new one out of wood or other material. I know PVC works well.I have fallen heir to a lot of kits with many older style Sierra click pens .... the ones that require the half-inch spacer. I see that there was a thread several years back about them, in particular this item by gwilki.
I am wondering if gwilki or anyone else can be more specific about fitting refills longer than the Parker ballpoint style to these older Sierra click pens and make them work. I tried using a Schneider rollerball and a Schmidt rollerball. While they are almost the same length as the Parker plus spacer, they don't seem to fit the Sierra click kits that I have.
Can anyone clarify or comment please. Thanks
Well that's a 1st. . . . . . . . . . . . . . . . . . For today.:redface:Thanks for replying, Bob .... but .... ummmmm .... I hesitantly suggest that perhaps you missed the point :biggrin:
Back to your original Question. I have no idea. :wink:I have these old kits for the Sierra click which require a spacer to be used with the Parker refill (refill is 98 mm long and the spacer is about half inch). I want to know if I can buy a refill which is 98 mm + half inch = about 112 mm long (ballpoint or rollerball) so that I can forget about using the spacers.
Of course, the diameter and profile has to match the Parker so that the replacement refill fits inside the pen and works with the existing spring and pushbutton.
If anyone knows of such a refill I would be grateful to hear about it, please (manufacturer and model number).
The old clicks were designed for a uniball or a g2 ball point refill and worked well with them.
That style has not been available other than as "new old stock" for a few years.
I sent a lot out the door with either uniball or g2 refills. Figured that with the longer refills there were fewer things to go wrong. There are a lot of g2 fans out there.
