OK folks, time to stop the "suffering"...!
You people have by now know that, I don't jump right to the winning award as soon as someone gives the correct answer, sometimes I like to see if there is anyone else that, also has the correct answer, and although I had stipulated that, on this game only one winner would be awarded, I always like to see how sure people is of their guesses and at the same time, allow enough time for everyone to have a go...!
With this said, I had the winner yesterday, I watched his great efforts at getting the correct answers, he was obviously not sure of the second wood species even though, he was very quick to work out what was that wood species that I mention on post #21, that was correct but in the incorrect order, that was the Silky-Oak.
On post #26, I found the correct answer however, I decided to play a little trick and make believe that, the Australian Ash could no the the one as off-course, our friend went all "gaga" and went looking....!:wink::biggrin:
As I mention, I have 2 different types of Ash wood, the bark is slightly different of each other, one is a more more rough/thicker and believe it or not, when I moved to this house, the ward had a very young tree planted (some other also) that I didn't recognize what it was however, when it grown a little bigger, I saw what was coming out of the ground and that when I discovered what it was. It looks now like this,
View attachment 127723View attachment 127724
This is the Ash bark I used,
As this is one of the pics that appear on the Google search of images of the Ash tree bark,
Sorry Wayne (1080wayne), I was just kidding...!
Congratulations Mr.1080wayne, you are a deserving winner on this game...!
resent:
So lets explain a little about these bark blanks;
The silky-oak bark was put aside some time ago when I processed some of the logs I cut last year, I then needed to process some Ask pen blanks and grabbed one of the logs I had in the shed, away from the weather for a couple of years so, the bark just peeled off by itself and, I grabbed it and in the way it was cut (on the cross cut side), I saw that, its characteristics would be interesting to see cast in resin, in that same cross cut configuration.
When I decided to cast some of it, I thought of the Silky-oak bark I had but, I had slabbed the log into 60mm thick slabs so, I could use it on the cross cut, I didn't have enough length for it so, I decided to cut some 22mm strips and cast them also.
Apart from many hours in the oven to make sure, was no moisture left in it, I stabilized it all with Cactus Juice (off-course) knowing that, bark is a buoyant material, nature made it with the intent to protect the tree from the weather and animal infestations so, tree bark is liquid repellent and very difficult to soak with anything, stabilizing does improve significantly the bark workability but, won't transform it into a solid/hard material.
After cast, all the resin/bark joints were soaked with super thin CA to make sure any separation was resolved with the CA. This has become a normal practice in 90% of the Resifills I make, I want to make sure, the 2 materials are adhered the best way I can...!
While casting, I use the new Shimmer violet from Pearlex powders that I like very much and also some of the always efficient Sky-Blue powder but, I decided to try something that I had in mind to try, for quite some time so, I used the opportunity to test my theory on creating resin "chunks" that will blend with the "running" resin, without leaving any straight sharp edges, as they would if the chunks were solid.
Anyway, the results were quite good and effective (fairly messy, though..!:frown
and I was pleased with the way both bark types, come out and I will be doing some more, in the near future...!:biggrin:
OK, time to wrap this up, once again, thank you to everyone that participated in this game, most appreciated. I will try to maintain the learning aspect, of these games...!
Your turn will be, next time...!:biggrin:
The winner pays the shipping of AU$14.00 to,
nyodine@yahoo.com.au
Cheers
George
