Hi Everyone,
I got a Turncrafter lathe and PSI pen turning starter kit for Christmas. I've wanted to turn wood for a long time and was super excited to get going. I managed to turn 2 pens, but halfway through pen #2 my wood started chipping. After some research on this forum I realized that the chipping was likely due to dull tools (along with a fair amount of operator error) and that I need to sharpen my (high carbon steel-not HSS) tools. Here's the thing, I don't have any way to sharpen and, actually, I'm dealing with a general dearth of tools--no way to cut, no way to drill, and I should also mention, no huge reserve of cash to play with (I'm a grad student; they don't pay us that well:redface
. So, I'm feeling a bit overwhelmed by all the things I need to get before I can proceed and the decision of how best to stretch my little bit of money has been all consuming. I'm hoping the you all can help.
What should I prioritize?
Should I maybe invest in a couple carbide tools for now just to get going so I can forgo the sharpening dilemma? Are there ways that I could begin sharpening that don't require a substantial initial monetary investment, but may require a little more time/elbow grease?
As far as drilling goes, I've been planning to use the lathe and just buy the necessary chucks, but I'm a bit leery because the tailstock on my lathe seems to have quite a bit of lateral play. I'm not sure if this is typical. I did call PSI and talked with them about it and they said that I should just figure out which side it pulls to and then compensate by manually pulling it in the opposite direction. I can't imagine this would work well for drilling, but what do I know? Is a little bit of left-right movement typical in the tailstock? Will it still work fine for drilling? By the way, I can get the tailstock to align with the headstock, but only if I manually correct it before locking it in position.
This brings me to another question about alignment. The mandrel I received simply does not align with the tailstock no matter how I adjust the tailstock. It's not off by much, but it is clearly rubbing against the dead center and just from the two pens I've turned there is already a groove in the dead center. Am I doing something wrong here or is this typical?
Sorry for all the questions. I just really want to get going, but don't know the best/most efficient way to make that happen. Thanks in advance for all of your help. --lindsay
