JD is EXACTLY correct!
Which points out one of the inaccuracies of the terminology that is accepted in penturning. We refer to the tubes by the size hole that is suggested.
7mm=.2755"--the size of the hole.
The tube is .268" OD
This is fraught with danger, since the INSIDE diameter of tubes is critical so that all the parts "press fit". But, we never refer to the actual size of the tube. Is PennState's 7mm the same as CSUSA's 7mm?? When I made pens, the answer to this was "not exactly". I don't know now.
