Need some help
Exabian
South Korea (Camp Humphrey)
Hello,
I managed to get my hands on a couple of 30 mm shell casings and I would like to repurpose it but it has the green paint coating the aluminum shell. My question is how would I go by removing the paint so I can expose the aluminum? Once I get that i will need to buff and polish the round. Any advice on this will be welcomed as well.
Thank you in advance for your assistance.
I'm far from an expert in these things & have never tried a 30 mm case, but you might try turning a tight fitting jam chuck to fit into the open end then mount it between centers on your lathe to sand off the paint & polish it.
I do that sort of thing with 50 cal cases - no paint to clean off, but I sand them to clean off the gunk & tarnish. I usually just use 600 grit but sometimes follow that with a couple of mm pads depending on how it looks. Then I polish with Brasso or a similar metal polish then spray with a lacquer formulated for brass.
Of course the 50 cal cases are brass rather than aluminum, but I would think that a similar approach would work with appropriate polish & finish.
I'm far from an expert in these things & have never tried a 30 mm case, but you might try turning a tight fitting jam chuck to fit into the open end then mount it between centers on your lathe to sand off the paint & polish it. I do that sort of thing with 50 cal cases - no paint to clean off, but I sand them to clean off the gunk & tarnish. I usually just use 600 grit but sometimes follow that with a couple of mm pads depending on how it looks. Then I polish with Brasso or a similar metal polish then spray with a lacquer formulated for brass. Of course the 50 cal cases are brass rather than aluminum, but I would think that a similar approach would work with appropriate polish & finish.
Thank you. I thought about sanding as well but I just wasn't sure if there was another way. I guess I was just worried about scaring the metal in the process.
If it is anodized, I would try something other than sanding. I found several sites claiming that Greased Lightning cleaner works for such things. Here's one that looks promising:
Removing Anodizing From Aluminum Quickly and Easily.
I have no idea if this will work for your cases, but it might be worth consideration. As for all such things that you find on the Internet - caveat lector!
That coating is probably anodized. I'm not sure what health concerns it might cause when sanding, but I would recommend a respirator!
Do you know of a safe way to take the anodized coloring off?
Normal oven cleaner should take it off. Do it in a well ventilated area or outside and use rubber gloves. There is a lot of posts about using oven cleaner to remove anodizing
I found some videos on YouTube about that but I've soaked it for 10 mins each time so fare but only a little came off.
Got it! I forgot one part which was to wipe it down, I was just submerging it in water. Any it's looking good now. Just need to clean it up more an polish it to mirror shine.
