Califo
Today I did a Sierra and went through the sanding process,  dry sanded up until 600 grit and then started with the wet micro mesh to 12000. After I started doing the wet sanding,  I noticed that some of the water from the sandpaper had seeped under the acrylic. This caused a darker spot around the edges of the finished blank between the tube and the acrylic. Has anyone experienced this?   Should I be wet sanding the acrylic?   The only possibility i could think of was that maybe there wasn't enough apoxy and caused a void between the tube and the acrylic for water to seep under it.
			- Could that be the cause?
- Can you think of anything else, maybe use wax between the blank and the bushing to fix this issue?
Thanks in advance for any input/ideas.
MARCO
