Gillette Fusion Proglide
See more from rd_ab_penman
rd_ab_penman
Red Deer, Alberta, Canada.
On a nickel plated Winchester .270.
Great seller at the gun shows.
Les
Has anyone tried to use the Artisan Fusion Heads on the PSI kits? I.E., is the screw insert on the Fusion head the same size as the screw insert on the Mach 3 head? Or, in other words, are the Artisan and PSI couplers threaded the same?
Yes, the Fusion and Mach III heads have the same thread and are interchangeable.
Les
