designer
There has been some discussion as to whether carbide or High Speed Steels are sharper or better. Please comment if you agree or not.
I use M2, M4 and M42 HSS and carbide tools. Mechanically there are some major differences.
Steel cannot take a lot of abuse on the end. It will give or dull or chip. Hey, it is steel. We have all seen it.
Carbide
Carbide in the metal industry for high speed lathes and mills can work or fail if not used properly. The depth of cut Must be greater than the edge radius. Most are not "razor sharp". They have a radius built into them. If the inserts that are being used on wood were designed for the metal industry, they will have a min of about .003 radius on the edge. Some up to .016 or more.
Again in the metal industry (not wood at this point) carbide has been able to shine over HSS when loaded down. Carbide does NOT like light cuts. Carbide does NOT like interrupted cuts. Now put it under a heavy load that is steady and it will peel off steel like butter.
On a mill with 4140 pre-hard steel at Rc 28-32 a 3/8 (side cut on and end mill) X 1 ½" (length) depth of cut will go just fine with carbide at some scary feed rates. HSS will burn up in a heart beat. This particular process was taking approximately 15 minutes with HSS with only a few thou depth of cut per pass. Changing to carbide it only took 32 seconds.
Wood will never stress carbide the same way. The wood will give long before the carbide will. Sometimes with catastrophic results. In other words, Explode.
The abrasiveness of wood will just dull the carbide like it will steel. It just normally takes longer with carbide based on the same cutting edge on each. The hardness of carbide is significantly higher. That does not mean it is always better for a given application.
Will HSS or carbide solve all your problems going with one or the other? You decide based on your experience and abilities.
Can carbide be sharpened as sharp as steel?
Carbide comes in a multiple grades from each of the main vendors. Is it a standard carbide? Fine grain or is it a Micro grain material? Is it C2 carbide or an exotic? Exotics can be sharpened closer to a razor edge (some can). I have sharpened a basic C2 (very basic and hard carbide) and cut myself on it and did not realize it till the blood got my attention.
Yes, carbide can be razor sharp with the right material and the right sharpening equipment and methods. Unfortunately, most of us do not have all this available to us. That does not mean we cannot sharpen it to a good edge for our use. Look at the CBN wheels for example.
The positive or negative rake on an insert to me is academic since we control that with the tool rest and angle of the the tool to the wood. Correct me if I am wrong on this.
What is next in wood turning? PCN or Diamond tools? Talk about over kill. Heaven forbid if one of them were to crack in use due to the cost of them. And don't ever drop one. Ouch in more ways than one.
I have asked the three largest carbide insert manufacturers about inserts for wood. All three looked at me like a deer in the head lights of a car at night. After getting with their engineering departments the answer was the same. "We have nothing for turning wood at all and would not know where to start. In other words, they don't make inserts with razor cutting edges. Carbide normally does not like that in the metal industry. Not wood, metal.
One round insert I bought I took to work. I put it on an optical comparator with 10X, 20X and 50X magnification with a DRO on it. I asked each of my three techs to check the edge radius (I needed a gage R&R anyway on this unit) at each magnification. The average results were .004 radius. Certainly not razor sharp at all. And this was a new unused insert. I spent lunch at my desk with diamond to hone it. I used digital micrometers to check the thickness to begin with. After reducing the thickness .005 I still had a .002 apparent radius on the edge. Was this due to a hone that was too coarse or the material the insert was made from? The hone was a cast iron lapping plate and diamond lapping compound. The surface finish was checked and was down to a 4 micro which is almost a mirror finish. It was the material in the insert being too coarse to get to a razor edge. It was a coarse grain material is all. That particular carbide will never be able to have a razor edge.
I have never done a hardness test on a carbide tipped saw blade. I assume they are a C2 material. It will hold an edge well due to the hardness. If someone has some good info as to what grade carbide they are I would like to know for my own knowledge. Those are sharpened to a very sharp edge and no radius of course.
Now which is best? M2, M4, M42 or carbide? What about D2 or Stellite? It might all depend on your own skills at sharpening and techniques in use.
Was the steel double or triple drawn? Was there a good controlled cryogenic process added?
I guess I am just suggesting to keep an open mind. Practice and get comfortable with each and learn how to sharpen to your own liking and use.
Well this should start some interesting comments.
Carbide
