Notnate
Hi,
At the risk of asking a question again that I may have missed in my search. I have been considering buying the HF pressure pot and some additional supplies to use it as a vacuum tank as well. Here are the extra parts I am looking at:
ProVac Vacuum chamber lid assembly
3 CFM Single-stage Rotary Vane Vacuum Pump
So in order to know if this idea would work I was wondering if anyone had tried this setup before? Is the HF pot opening the right size (10") for the lid assembly? And is that vacuum going to be good enough for stabilization?
I did the math on the vacuum and according to their specs it should pull nearly 30 inches of mercury. The reviews on it are awful iffy though.
The lid I'm sure will work provided the opening on the pot is large enough and not so sharp as to cut the gasket material. I could even alter the lid some with thicker gasket even if it is, so long as the lid will fit.
Thanks in advance for any thoughts.
