Grizzly and South Bend Chuck Opinions?
I added on a similar Grizzly chuck on my DP. It's not a $200 chuck, but frankly I cant tell the difference. It runs true, does not work loose, and grips well. Mine is larger than 1/2 and that would be the only reason not to buy this one. If you only need 1/2", it's a good buy.
I have this one for my metal lathe...
Grizzly.com
I think it's the same chuck but it has the integrated 2mt shaft. If it's the same then you'll like it, very well made. All the SB stuff is a notch above the Griz stuff but you pay for it.
I have had several Grizzly items before I knew better, but I have none of it any longer. Everything I purchased fell apart or I had to modify it to make it better, including a lathe and chucks. I have not owned the keyless but would venture to say that if you are planning on using it for anything other than very occasional, you'd do better to invest in something better.
