bjbear76
I had ordered some cast blanks that included instructions not to wet sand due to the possibility of moisture getting to the paper on the tube.  So I turned a couple blanks last night, dry sanded with abranet followed by MM.  I finished one with Novus, the second I buffed with white diamond.
In my opinion, they both came out every bit as good as when I wet sand.
I may try a couple more, but it seems that I can avoid the mess of wet sanding and go this route. Maybe just for clear cast acrylics??
Do any of you strictly dry sand/finish your acrylics? Are there any other pro or cons that I should be aware of?
Thanks,
Bill
Thanks,
Bill
