I'm having a problem, and I wonder if anyone can shed some light. I have been trying to cast stamps, and I am getting a staining effect in spots (see pics).
The first pic shows stamps that were never uncirculated self-adhesive stamps. I simply stuck them directly on the brass tube and coated with mod podge.
The second pic shows older stamps that were adhered to the tube with mod podge, then covered with more mod podge.
I use a top coat of mod podge on both, then let cure for a couple days before casting.
I had thought at first that the self-adhesive glue on the newer stamps might be the culprit, but then it happened on the older ones as well. It only seems to happen on the ends of the older stamps, while it is on all the seams of the self-adhesive stamps.
The casts were made with Alumilite using a pressure pot.
I rough turned the blanks and polished a bit to show the problem.
Can anyone suggest a solution?
Thanks!
Thanks!
