TimS124
Finally got a chance to try some more casting experiments.  Somehow, the mold I've been using was missing so I grabbed another (larger) one that hadn't yet been used.
I also didn't have my notebook with my notes from prior experiments...which would've helped quite a bit with figuring out how many grams of resin to use for the mold...
Ah well, it's a different/larger mold so the numbers would've been only partially helpful. Time to wing it.
Measured out two matching sets of Part A & Part B (white Alumilite), added dyes to the Part A cups, poured one of the A cups into the B and stirred for 30-45 seconds (guessing the time...didn't use an actual stopwatch this time around).
Then poured the other A into the remaining B and stirred for 30-45 seconds and reached for the first cup to pour/swirl them into the mold.
Ooops, the first cup had gone off already. Sheesh! It had been mixed for maybe a minute, surely less than two...but it was already un-pourable.
Slapped the still-liquid second cup's contents into the mold and got it under pressure.
The mold leaked and I underestimated how much total resin to mix. So, the second color produced a 1/4" thick slab and the first color produced a cup-shaped block. Both colors came out lighter than I wanted (I'm still working out how much dye to add to overcome the effects of the white in white Alumilite).
The cup-shaped block maybe become a tiny bowl or a wine stopper. That depends mostly on how deep the remains of the stir-stick run (yep, it was stuck in there when the mix went off). :big grin:
The slab I'm not yet sure what I'll use it for, but I'm certain I can find something.
The resin was in my garage today and today's high was about 72 degrees F. I'll bring it inside (where it's air conditioned) and try again tomorrow night.
