woodwzrd
I started this thread yesterday in what I thought was a new thread but actually ended up hijacking a different thread because I hit the wrong button when I intended to start a new thread. Any help would be greatly appreciated. Thanks
I have cast quite a few waste wood blanks using off the shelf fiberglass resin and have really never had any problems other than the color gets muted because of the tan color of the resin. I recently bought two gallons of Silmar 41 and I have cast some buckeye burl, cocobolo, elm burl, cherry burl, and some maple burl. With the buckeye and the cocobolo I had issues. I am using 7 drops of MEKL per ounce and I am casting in HDPE molds that I made. I am casting under 80# of pressure. With the cocobolo the blanks did not fully cure out in some spots mostly on the bottom. With the buckeye the resin seemed to want to pull away from wood. The rest seemed to cast ok. Is this a known problem with woods like buckeye and oily woods like cocobolo? I have quite a bit of coco and buckeye to cast so any help or advice would be greatly appreciated. Thank you in advance.
