Overkill??
Yes it is overkill. Big Time!
Plan on a new electric line to your shop area. You will need a specialized transformer to convert single phase to 3 phase 220 or 440 volts depending on the machine.
Wood tends to jam up under the wipers on the ways as well. It will turn wood, just not designed to be used for that.
Did you have a sideline of making large bearings or machining shafts for equipment? That is more along the lines of this machine.
Dont listen the the nay sayers in this forum. It is perfect for turning pens. Why the rigidity of the ways alone mean sub .0001 accuracy. Out of round on your pens will have to be measured with a laser. But the best part of all is you can turn up to at least 20 pens at once on a 80 inch mandrell. Sure you need 3 phase power who wouldnt with that beast but you can buy phase converters.
You would be THE MAN among men of the pen turning world. A 12 x 36 would be a childs toy to your lathe. As for price, at 20 pens at once and hundreds of bushing sets at a time you could sell enough to pay for that lathe in no time. Only the small minded and weak cannot see the glory and fame that awaits you.
If you think that lathe is expensive try buying a boat. A boat wont make things like a lathe can and gas is much more expensive that electricity. I say you go for it.
Hey That would go with my pen blank order.
Dennis
That pretty much sums it up.
So meet up at Allen's place to set things up then everyone????:biggrin:
Is it an overkill? Is a BullFrog waterproof?:big grin:
I would like for making pool cues, canes, bats, toothpicks.
Here's one of the small lathes at work that I'm hoping to get some lessons on:
The small chuck:
I couldn't fit a close up of Abe's face and the whole chuck in one photo!
How about a little live center to work with?
And I figured I'd get a shot of the largest drill laying around:
So, I'll try to get some lessons and make a pen that fits the lathe...look out PITH partner!!
