Victorian pen issues
Airbear77
Dunn, NC
I have done 4 victorian pens and all of them have the same problem. It seems something is pinching the refill and not allowing the tip of the refill to retract into the pen. If I unscrew the tip of the kit a little bit, it will retract like it should. Is anyone else having this problem?
I have not worked with this pen kit, but have had this problem in the past on others. The tapered tip may be a little tight when the refill is extended. Slide the refill into the nib point from the front and see if it binds. You can also try shortening your spring a little. One of these should work. Jim S
