Displaced Canadian
I learned that with a metal lathe if a bushing is oversized and out of round you can fix the bushing at the same time you turn the pen.
The corollary to this is that the metal lathe will also happily remove material from things you didn't intend to remove material from. Some people might consider this a disadvantage rather than a design opportunity.:biggrin:
Daydreaming or getting distracted with the power feed on can get exciting!!
Ed
I hear this is true, but it never happened to me. I intended to shave that bushing down.:tongue:
There are lots of advantages to a metal lather. I lost a bushing so I got out the calipers and piece of stainless and made my own. I just wish mine had taper capabilities.
You're going to stick with your story when the tool bit hits the chuck jaws or the jaws hit the carriage,:crying: right? :wink:
Chris, shame on you for even saying, let alone using, stock bushings when you have a metal lathe!!!!!!
Why can't you do tapers? Top slide for short tapers, tailstock for long ones. If your tailstock can't move then use a boring head in the TS with a rounded pin.![]()
Now to make it fit and find out what cutters I need.
My quick change tool post just came in. Now to make it fit and find out what cutters I need.
What do you think pulled my attention away from the hottie in a bikini waxing her boat? Every once in a while I see the positive part to running a boat storage facility. Now, before I get called a pig you gents would have been doing the same thing. When the jaws get hit it makes a terrible racket. I was damn lucky I did not screw up the chuck.
