CharlesH
Hey guys,
I have gotten into knives and I have a languiole made of snakewood and I decided I needed a pen to go with it.
I had fairly good luck with snakewood, I have had a few pens not crack on me yet with my usual CA glue finish.
Yesterday I prepared a two tubes pen and I noticed the snakewood was cracked all the way down so I was kinda worried and I decided to not finish it. It is related with the heat build up while drilling. I am not really interested in wet drilling, in my mind I think it would make the wood even more unstable.
From that point I contacted many some snakewood suppliers and woodworkers to get some input from them. So I drilled the snakewood and micro-cracks appeared since I could not avoid heat. I thin-CA'ed inside the tubes holes and all the blank with two good layer of CA then pierced again. I wanted a barewood finish with this pen. So I turned the pen to the bushings I applied thin CA on the end of tubes and on the tube itself and I went with sanding up to 1500. I applied renaissance wax as finish. The pen feel really heavy/saturated and dense without any voids. I am pretty confident it will last, I will put it to test.
If you guys have any input regarding this wood it would be fun to hear about it!
As always clicky the thumbnail:
Thanks,
Charles
Thanks,
Charles
