Bolt Action question
Smitty37
Passed Away Mar 29, 2018
Milford, Delaware 19963
How do you rotate the clip on the PSI bolt action - I got the bolt turned around easy enough but I'm not sure about the clip---it says Rotate Clip on the instructions but I'm not sure how. Anybody done it?
Yep. That's how it works. Once you loosen the screw in the cap, the finial should turn off allowing you to move the bolt to the other side, IIRC.
Glad i could help Smitty. I wasn't 100% sure about it when i posted that, but was thinking one of my kits had a loose finial when i put it together and had to tighten it.
Harry
