One man's trash, is another man's treasure!
Pitoon
Vicenza, Italy
Just as the title says! I usually pass by our recycle center on base a twice a week to see what goodies people decide to part with. Several weeks back i looked inside the compost container and found a nice size uprooted tree stump. I immediately though to myself, jackpot! Someone was nice enough up pull it up from the ground for me to find and cut, lol!
So today i decided to cut up the stump and low and behold some really nice blanks to add to my stock. Great grain, burl, and spalting mixed up amoung the blanks.
I was thinking they would look a bit better if i let them spalt some more. So i put them in a grocery shopping bag poured some water on them, and then double bag them in a thick paper bag. I'll probably pull them out to dry around Easter.
Unfortunately i have no clue what wood the blanks are?
Thanks for looking!
Pitoon
It looks similar to some apple I also got from a stump. My stump came from my brother in law's yard. All I had to do was help him get it out of the ground. Your haul is better than mine. I only got about 4 good blanks, and had to replace my band saw blade. Stumps are tough with all the trash that the root ball grows around.
Wow, only 4 blanks? That must of been a really small stump? This stump was about the size of a medium watermelon. I had to do a lot of clean up before i started cutting. I even found a clay brick tangled up in the roots.
And yeah call me crazy.....but i cut the stump on a table saw. It was a challenge needless to say and a 14in blade standing a little over 4 inches cutting height didn't calm the nerves!
I cut the blanks 1in x 1in. I'm curious to see how much they will shrink when they dry.
Pitoon
Nice score Pitoon. Not sure what it is but I don't think Olive based on what Robutacion said about your Majestic. He said that olive doesn't spalt like regular woods it kind of turns grey.
Mike
Well, certainly not Olive wood...!
With those yellow colours, it matches the Mulberry, the root/butt end has normally the bright yellows and that white(ish) areas, there is a simple test that can determine if is Mulberry or not as Mulberry is one of those woods that darken considerably when exposed to light so, put a couple of those blanks in the sun for a week or so, bring them inside and compare, the yellow will become brown...!
Cheers
George
Cheers
George
Interesting! I wish you saw this thread before i packed them up to spalt some more.
Since you're than man with the answers on wood. What do you think about spalted mahogany? Would you think it's worth to try? I've never seen any available. I have a good slab in my garage about 6ft long 3inch thick and about 1ft wide i could cut up and try. But if it's not aesthetically pleasing to look at i won't even bother trying to spalt it.
Have you came across any spalted mahogany?
Pitoon
Cheers
George
Pitoon
Well, I know a bit about some woods and tree species, particularly those that I have had hands on experience with, what I know is only a scratch at the surface of the issue and some people have spend their life time studying the subject, one person that I know with 60+ years on scientific work in this area, has told be some time ago that, he will die not knowing more than 1/10 of what is there to know, and I have no hesitation to agreed with such statement...!
In relation to your question, mahogany does spalt and can spalt very well however, there are dozens of mahogany subspecies and they behave all differently when it come to spalting so, not knowing which one you've got, you could try to provoke spalting by cutting a section of that wood you have, soak it really well and while wet cover the whole thing with "ash" from any burnt wood pile or fireplace. The ash powder will stick to the wood and you then wrap it all around with news paper, 3 or 4 layers of it.
Use use fine string to keep the news paper in place, find a plastic bag big enough to put you wood piece in it and fill the spaces around with saw dust/shavings. Before you seal/close the bag, use a garden hose to wet the hole thing well. This will make the bag quite heavy so, you should first set a place where the bag will stay for awhile, outside if possible.
Seal it properly so that no air gets in, that will force the wood to soak what it has available inside that bag. Leave it alone for about 6 months, then open and check, if right take it out to dry completely if not, repeat the procedure and give it another 6 months. After 12 months, you will get all the spalting that wood is capable of, the ash will colour the water as it soaks through the wood, and if everything goes right, the fungi that produces the black spalting will have extra nutrients in the ash to produce more dark colourations, is like fungi on steroids...!:biggrin:
Again, spalting is not something that all woods are capable of, I prefer to leave that job for "nature" to do, up here, most woods spalt quit fast in the paddocks, infact so fast, that I keep find trees that I'm a couple of years too late and I missed the best spalting time, what I get left is basically, dust/sawdust...!
You lose nothing in trying, right...???
Cheers
George
Pitoon
the problem was that the stump was in the ground for about 2 years before we dug it out. It was really punky. I guess I could have stabilized some of the blanks, but they were pretty far gone. Before I started cutting, I think it was a little larger than a basketball.
I probably spent about 45 minutes with a pressure washer getting the dirt, gravel, and as much grit out of the root ball as I could before letting it dry and cutting it up. The few pieces I got were pretty, but not really worth the effort or the blade.
You cut yours on a table saw? I would have been more than a little nervous.
