I am wanting to do a 6mm kitless pen, and I just want to make sure that I have the tooling straight before I go out and spend some money.
I want to get a 6mm JoWo nib with the corresponding 7.4x.5mm tap. For the section to body threading, I figured I could get a 10x1 tap and die set, which would allow me to use El Grande nibs if I ever wanted to. Then for the body to cap a 12x.75 tap and die set.
Does this all sound reasonable? Is the wall thickness between the 10mm threading and 12mm threading on the body enough?
Thank you!
Thank you!
