Organization
I previously used a tackle box. I thought it was great. Had each compartment labelled. Then it got knocked off the workbench. With a hundred or so now un-categorized bushings, I decided I needed a better plan.
I now use a vintage wood toolbox. I just like the look of a really old toolbox on my bench, I have two. One for tools, and one for pen parts. In one drawer, a short and narrow one, I put all the bushings in their original labelled bags. They are managing to stay organized.
YMMV:biggrin:
bushings, extra parts, and "stuff" go in drawer cabinets like these:
Stack-On | Products | 60-Bin Plastic Drawer Cabinet
if I have more than one set of bushings for a pen type, I'll hold each set together with a small wire tie in the drawer - so one drawer may have 3 sets of cigar bushings in it.
kits are kept shoe-box sized clear storage boxes under the work bench. One box for 2-tube kits, one box for single tube kits, and one box for kits that my son can use.
I keep all my bushings in their original plastic bag, marked with the pen kit(s) it goes with, I keep those in two of the bins in a small plastic box.
They're easy to find, and stay organized. If the box ever gets dumped it's no problem, they're in marked bags.
I move my turning operation inside in the Winter, it's too cold out in the garage in Wisconsin. So keeping all of those little parts in their bags in a box makes it easy to transition to the inside shop without a lot of "retraining".
Happy turning
I use a couple of pill boxes for my bushings. I used solvent to remove the days of the week on the lid of each compartment and then wrote on the lid the part no. of the bushing and style. For blanks, I made a 3-shelf (saw the idea somewhere) assembly that has cookie baking sheets that slide onto each shelf. Put all my blanks in there and can slide each sheet out like a drawer.
Holes drilled in hardboard with pill bottles.
Pen kits go in plastic shoeboxes; the size varies depending upon the amount of kits to store. Labeled on the exterior. For example, all the Cigar kits from the various suppliers go in the same shoebox, separated in heavy duty zip top bags that show the contents. The CSUSA click Cigars use different sized tubes and bushings so they're in a separate shoebox. El Grande ballpoints, fountain pens and rollerballs are in a separate shoebox.
Bushings go in plastic snap top containers that will hold two sets in the original plastic baggies. Labeled by bushing number on the top (where available) with another label on the side identifying the kits that the bushings go to.
Spare parts in plastic compartmented boxes, labeled on the outside for identification.
It works well for me.
Matthew
Same as The Penguin uses, except I use some with larger drawers for pen kits. Large amounts of pen kits, wood, PR blanks, and special tools, chucks, mandrels and the like go into Sterlite boxes.
I have been using these boxes for several years. I got them at Harbor Freight. Sometimes you can find them on sale or use a percentage off coupon. At $4.99 they are pretty cheap.
Having them in individual boxes sure helps if you drop the main box. :eek:
Each little box has plenty of room for any bushings.
I cut the name of the bushing off the bag and put it in the box.
I have three boxes and lable the main box A, B, C and then number each little box 1 -24. So, a Sierra bushing set might be in B17. I then have a spread sheet for each box with the bushing description (pen name, etc), the vendor name, and the part no.
Sure is easy and quick to find a bushing.
24 Container Storage Box
Oops - sorry for the picture size..........
Hope that helps.
gordon
Peg board for the kits, keep all alike in a Ziploc bag hanging with instructions inside the bag, bushings stay in their original bag and then in a compartment box (kinda like a tackle box) clear lidded and I write the bushing name on the outside of the box. Drill bits all together in a plastic box. Shelves for blanks, glue etc.
For pen kits, I use a HF freestanding rack with plastic bins that hang on rails on the back of rack. Works well for me.
I use the bushing storage system as Fly it Fast.
I built a rolling pen storage unit that has two wide shelves on each side at the bottom and the top I made so it will hold 40 of the harbor freight gray plastic trays on each side. I use a 32 bin I think plastic storage unit that I bought at Ace Hardware to keep bushings, extra drill bits etc. in and that is mounted on the end of the upper cabinet.
Clear plastic shoe boxes for each kit. Each shoe box has all of the kits and bushing and anything special needed for that pen. When it comes to ordering I can look at the boxes and order my resupply in almost no time. I try to make large orders, once or twice a year, I would rather have everything in stock than waste money on shipping charges if I order a few kits every week or so.
Here's a shot of how I keep my kits:
Instagram
It doesn't look like it, but I have roughly 90 kits there, grouped by pen type and then different hooks for different platings for my more popular kits where I keep a lot on hand, others with just 2 or 3 of each plate type share a hook with the others of the same kit.
Bushings I keep in a small plastic case with dividers in their original bags. I have another case for drill bits where I took out some of the dividers. Tubes/spare parts go into an empty coffee can, but that is starting to fill up and will probably be replaced during Spring Cleaning.
