mightymavkev
So I've been experimenting with a "different" finish for antler then CA. I've noticed several folks for whom I've made antler pens have had the CA finish dull on them where their fingers hold the pen the most. Some are worse than others and it definitely seems to vary by person (which give some merit to that one theory I read someone give that we all have some acetone in our skin
) I had one that I made actually look like the finish came completely off where their thumb held the pen, but I'm more inclined to believe that one was just a bad finish on my part.
Anyway, I have been doing the Pens Plus finish with Doctors walnut oil using Mike's process that he described for his wood pens on my antler. I actually kind of like the way it comes out. It's leaves a satin finish but still leaves the texture of the bone to the touch. Kind of makes it a little more "natrual" looking (and feeling) in my opinion. The even better news is that my 2 test pens out there with this finish are holding up so far. So time will tell, but positive to this point.
But even if that option pans out, there's always going to be that desire for a nice glass like finish and I started thinking about something and I wanted to know if any of you have tried this already or if you all just think I'm nuts (which is only partially rhetorical)
I was wondering if I could turn the blank first to BELOW bushing diameter but not as far as the tube. Then cast it with clear resin in one of those "tube in" type molds, then turn that back down to bushing diameter.
At that point, the finish would resin and not CA and would only require wet sanding and buffing and I believe the antler would look just as good as it does after a brand new shiny CA finish comes off the buffer.
I'm not sure how well this would work and I realize it's ALOT more work than maybe it's worth, but whenever I get setup to dabble in casting, I'm thinking I might try it just to see what happens.
I figure worst case, I just turn it all the way back down to bone and make a slimline instead of a bullet pen.
Again, I'm inviting the backlash if this is stupid, just be gentile as it's only an idea.
Thanks all,
Kevin
Thanks all,
Kevin
