Die holder
I have that. I started out with it and quickly went to the one from little machine shop. There's not any one thing that jumped out at me, but I felt like I wasn't getting the best job out of it. Just remember you have to hold it in your Jacobs chuck. I didn't like having to spin the collet chuck to cut the threads. On the LMS one you spin the actual die. I get a better feel of the threads being cut.
If you want to give it a try shoot me a PM and I'll send it your way.
I have one and I must be the only silly enough to put a pin in the tail stock chuck and slide the die holder over it and spin the die by hand, letting it self feed over the pen part. I don't know if it would work on metal but ebonite and plastic are within the range my wimpy grip. ;)
After looking at the die holders from LMS and victor, I decided it was overall a better design for the LMS die holder. I couldn't be happier with it. I'm sure the victor will work as intended, but it comes down to what works for you.
Pete,
Sounds like a great idea. Could you explain the "pin" and maybe provide a picture? Thanks in advance.
-Dave
I use the nearest transfer punch that fits the hole. :smile: A chunk of hardwood turned to size will work in a pinch. :wink:
The pictures are quick and dirty because it is close to freezing in the garage. :rolleyes:
