New HF Lathe
Band Saw Box
Passed Away Dec 8, 2021
Hampton, VA 23666
My HF Lathe arrived today, this time there was no damaged to the box and none to the lathe. I set it up and checked to see if the head and tailstock were in alignment and they were perfect. I wasn't sure I would like using the hex wrench to loosen and tighten the motor when adjusting the belts. It runs very smooth and is a joy to turn on. I have it setup in our back room so I can turn in the coming colder months.
As long as I clean up after myself I'll have no problems and I dont plan on turning anything but pens or maybe a stopper.
You can change the bolt out for a handle like the Jet for loosening the motor mount. WC sells them as well as the big box stores in the specialty hardware section. Just a thought.
I just checked the bolt in reference to the motor, it's just a 1/4" away. I'm wondering if that kind of handle will work. If the way it is now is fine.
That is HF version of the Excelsior lathe sold at Woodcraft. I have had one for four years, and still use it more than my big variable speed. It will serve you well. And, yes, the handle will fit. It is a lever type handle and replaces the bolt.
I know I'm not addicted, I can stop any time I want, I just dont want to and please, please do make me.
I have the HF 10 speed w/ reversible head.
Love it. Dead on and has no problems turning some larger pieces. My only wish is that I would have bought that one first. I got the little variable speed, but it crapped out after 3 pens and a small gavel.
