Where to get Slimline (7mm) TBC bushings?
sschering
Eugene, OR
Where can a guy find a set of TBC bushings for slimline kits?
I checked Lazerlinez, Smittys and Penturners with no luck unless I just missed seeing it.
One answer is that you are out of luck. The only major supplier I'm aware of is penturnersproducts an he is not actively restocking at this time to my knowledge.
Your options that I can see are make your own or find someone with a metal lathe to make them for you.
Well I guess I could mount up the cross slide and turn down a couple bits of drill rod I have.
My lathe isn't exactly the most accurate thing in the world when it comes to metal work.
I grabbed penturners last set about 4 months ago and he said they were his set. Didn't sound like he was planning on any new production either.
Mike B
Others might disagree, but I see a big hole in the market if Johnnycnc decides not to procure more.
I honestly don't know wether he will I won't.
It is my understanding that he's not turning pens himself anymore as he sold me his personal use bushings.
If I can find the set I have I'll get back to you for your mailing address.
That would be great.. thanks!
They have seen some use but there is still a lot of life left in them, they are from Penturners Products.
I will PM you the details.
