Gloves and lathes don't mix
triw51
407 East Cottonwood Drive, Cottonwood AZ
I have seen several videos of wood turners wearing a glove or gloves while turning usually bowls or larger objests. I was always told that was a BIG NO NO.
The other day I was sanding a pen blank and needed to fill a small worm hole with sawdust and CA glue. I put on a thin rubber glove and delt with the problem. I started to sand again (with out removing the glove) next thing I know that glove was yanked off. So fast it was unbelievable, if that had been a cloth or leather glove my arm would have been wrapped around my work before I had a chance to react.
That incident reinforced the NO GOLVES AT THE LATHE rule in my shop (even thoes thin rubber ones I get from my Doc.). And while on the subject I take off my rings and anything that could get caught. Just a reminder to be safe
This thread brings up a question... I get little cuts in my fingertips in the winter from dry skin. It makes sanding sort of painful, especially inside boxes. I know the best solution is to prevent the cuts, but hand lotion doesn't help because I'm not too religious about it. I usually use bandaids, but they are not a very good solution. I thought about using a finger cot or a leather thimble, but I imagine those could be torn off as well. Anyone solve this problem?
Jeff,
My hands/fingers so the same thing. Sometimes I think I can just sand with my rough skin. It is good though...I can rub Wonderful Wifeys feet and give them a loufa treatment at the same time! :biggrin:
Sandpaper on a paint stick or dowel..piece of rubber or vinly hose. Anything and pad it to be flexible andfit the area to be sanded. Might work except on very small work.
Goos luck!
No...I'm not kidding...dip your finger tips in melted wax...luke warm if possible. It's an old physical therapy trick to moisturize the skin before hand therapy
While I agree about the safety I disagree about the gloves. If they are they sterile nitrile gloves (like the kind you likely used and didn't get injured) then wear them. They will rip off and spin around the lathe before your hand goes in. I've had them catch and rip off a few times and not a single injury from it. Only shop injury I had was nothing I do with gloves and everything to do with why I'm afraid to turn bowls right now.
I use a glove with the fingers cut out on occasion when turning some bowls.
don't think I'd want to use any gloves with the fingers still on them.
I have used the cut off finger of a latex glove when I needed to protect my finger from glue. If it should catch, it pulls off easily without endangering your hand.
Great idea - I use the thin disposable nitrile gloves when applying CA to my blanks. They tear quite easily so I haven't really worried about it, but I'm going to start using just the finger tips of the gloves for an added measure of safety.
Jeff, one thought I had was to use a product that I had when I lived in Illinois. Can't remember the name, but it was used for bowlers who had torn their skin their thumb. New Skin or something like that. Coat it with that while sanding anbd that will protect it until you use enough hand cream to remove the cracks.
Hope that helps.
Also, moving south works like I didn....
New skin is basically CA, maybe clear nail polish. My son in law used CA for a field dressing in the marines.
FWIW I am of the opinion that we are mixing apples and oranges here. The rubber gloves will catch and tear off easily and probsbly not injure anyone.
I have a pair of mechanics leather palm gloves. They fit skin tight and have a Velcro closure at the wrist. I don't often wear them. I use them when I am turning something and the hot wood is burning my hand. Otherwise bare handed. I don't feel those gloves are in danger of getting caught. I just don't like to loose the ability to feel the work.
For cracked hands Glysomed is very good and while it is better if used often, it is pretty good in intermittent use. Also get yourself some unrefined Shea Butter. It is great.
I guess I'm in the minority here then... I wear a weight lifters glove on my left hand when I'm turning... the wood chips that are cut away and hit the side of my hand makes my hand sore. The gloves protect the hand from the constant bombardment of the wood. The gloves are very tight fitting, slightly padded in the palm and have the fingers cut off at the first knuckle from the palm. I don't remember who, but recently watched a video of a pro-turner who was also wearing gloves like mine.
I do remove my rings.. I've already broken my wedding ring once.. plus I had a buddy that lost half a finger jumping off a truck and caught his ring on a bolt on the side boards... that was almost 50 years ago and I still shudder when I think about it.
For what it is worth (not much) I always wear gloves when I am turning or working on anything in the shop because women hate hands that look like a grease monkey....the brown jersey type that you can buy anywhere, HOWEVER, I put rubber bands around the long sleeves of my shirt, always wear a full face shield and always stand to the side when I am turning in case things start flying. I never put my hands anywhere near things that spin when I have gloves on and take them off if I need to get close.
I guess being careful has worked for me because I've never had a glove injury issue - yet.
Jeff, like you I get the dry hands which is why I wear the gloves. Helps a little bit. So does a can of Bag Balm that sits on the bench and I constantly dip my fingers in it.
Jeff, Two things come to mind that may help you out. One...dab a little CA on your cuts and let it dry before you start working. (I am an EMT and worked in a hospital for several years. The DR's. always used "super Glue" to close cuts that were to small to stitch.) Second...If you don't like the first idea, go to the pharmacy and get a bottle of second skin or liquid bandage. Its pretty much the same thing as super glue but it dries slower and has a brush to apply it to the area. Either one will close the cut and protect your fingers from debris getting into the opening. Hope this helps.
The only time I wear a glove (singular) is on my right hand (I am right-handed) when turning extremely dry walnut. The shavings can really sting when hitting old, thin skin.
Gloves or not, paying attention to what you are doing and being aware of the immediate sights and sounds is what needs to be done whenever you are working with ANY tool that can mangle a (insert body part or small animal here).
Jeff paraffin wax is precisely it. A good trick is to take some latex gloves that are oversized and fill the fingers with the wax (hot but not burn you hot) and shove your hands in. Let that sit until it hardens and is cool. Then remove them (second set of hands is useful here). Then put some good lotion on and go to bed.
Or go get a manicure and get a nice purdy color when you're done. Just make sure to get the one that they use the paraffin wax with. My hands get pretty messed up from time to time do my wife takes me to get it done. It only feels weird if you let it. Well. It still feels weird but your hands will feel better.
My fingers use to crack open when working outside in the winter until I started using Utter conditioner for the local tractor supply. I have had some pretty good success with Cornhuskers lotion also.
I'll share this with you, but don't tell anyone...I have not had a manicure with the hot wax, but I did have a pedicure. I was a little leery of dipping my tootsies in that big tank of wax, but he technician was very cute and very convincing (cute) and seemed to know what she was doing (cute) so I took the plunge. Wow that was relaxing! I fell dead asleep. If it will help the finger cracks, I will give it a try.
Melt it gently on the stove I presume?
http://www.amazon.co.uk/Elastoplast-3197571-Spray-Plaster-32ml/dp/B0026RH1ZM
Worth a shot!
O'KEEFES WORKED FOR ME WHEN...
Jeff,
O'Keeffe's Skin Creams to Protect and Relieve Dry, Cracked, Split Skin
This stuff worked well for me when I was a maintenance supervisor (working-the kind that got good an dirty and nasty). Frequent hand washing, chemicals, dry air all contribute. Only wish I knew about it when I was an office machine technician for 41 years. Fingers used to crack and bleed. Some repairs were very painful. Back in the day we used laquer thinner to clean rubber parts and other degreasing.
Buy several, I used to find mine at register and in plumbing dept at Lowes. Reasonable price, $6-7 or thereabouts. Get sevral, keep in vehicle, and wherever you wash up, night stand. Frequent, application works. Use sparingly, rub a little extra into cracks.
Target, Grainger, and many drug stores carry it, even Harbor Freight.
Green for hands, blue for feet. We used to send to this to our former son in law in Iraq and Afghanistan. He said it was the only thing that helped him.
One other product that I had good results with, but was hard to find was Zimms Crack Creme, both liquid and paste if memory serves. Hard to find the stores who carried it and frequently they would stop carrying it.
Charlie
A bitt heaver then Cots or Nytrile glove fingers... Bet you can find similar at Office Depot or Staples.
Turners Select Rubber Finger Saver Set | Finishing | Craft Supplies USA
Found these and I ordered a few to try out. I don't know how they'll hold up to sandpaper, but we'll see.
Having lost the better part of middle finger, left hand, I wouldn't suggest wearing ANYTHING on my hands or fingers.
think about it, if the hand glove or "finger" glove enables you to hang onto to the piece a bit better, It just might enable the lathe to grab hold of your finger a tad bit better.-Or, in my case a saw blade. And I wasn't wearing anything on my hands. It all happens so lightening fast.
the gent from Blackpool had a good suggestion after the fingers crack. I have used a similar spray with good results years ago. Today I just wince while I'm turning and put on neosporin (sp ?) later.
Just my 2 cents worth and probably is worth much less:smile:
Russ
The following is extremely graphic. Delete if not appropriate for the forum.
Do not do this search if you are at all squeamish.
If you are somewhat complacent with the lathe and the use of gloves, Google 'degloving injury' and go to the images page.
This type of injury is no joke. Sorry if this post offends anyone.
Sandy.
Sandy.
just reading that send a shiver up my spine...not sure I want to google it.
Sandy.
I honestly wouldn't google it if you are unsure, but since it is safety related, I thought it would be worth putting out there.
Sandy.
Interesting to note that a good hefty majority, if not all, of those 'images' are results from non-lathe accidents.
Even then if you only look at 'lathe' injuries you will see that most of them happens with high speed and high torque lathes, i.e. metal lathes.
Fundamental rules in industry when running machinery:
No long hair
No loose clothing
No gloves
No jewelry
The Air Force used to have a picture of a man's hand with a missing finger and the finger on the floor a real bloody mess, but served to remind me of one of the basic safety rules.
Ben
I used to read blue prints all day (the kind that was developed by amonia vapor) and the residual vapor on the blue print paper used to crack my hands. a co-worker in the engineering department put me onto "corn husker's lotion". Really helped soothe and heal my sore cracked hands.
I too noticed some videos of turners working at the lathe (turning - not finishing) with at least one glove - and sometimes two. I have seen a man who lost a finger when his glove got caught on the revolving workpiece (wasn't there but talked to him later in his life). I was taught in fourth grade woodshop: No gloves, no long sleeves, no jewelry when working around any machine. I still follow those rules over sixty years later.
Gloves and lathes
I posted this little incident in February 2013.
I was so lucky to not have a single piece of skin removed or bone broken, BUT I did completely stall my 1.5hp lathe when my glove and hand wrapped around the workpiece.
Like I said, LUCKY.
Bob.:eek::eek::eek::eek:
